ball joints: how to..
Old Feb 27, 2007 | 12:40 PM
MATiC's Avatar
Default ball joints: how to..
so i've explained my problem of something suspension related making a popping sound when i turn steering wheel from one side to the other.. everyone seems to say it's my ball joint..
so im wondering what would i be looking for while looking into it..
if i find something to be wrong with the ball joint, could it be something i could replace myself or would i need a mechanic..?
thanks..
ps: already searched
Old Feb 27, 2007 | 12:48 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ball joints: how to.. (MATiC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MATiC &raquo;</TD></TR><TR><TD CLASS="quote">so i've explained my problem of something suspension related making a popping sound when i turn steering wheel from one side to the other.. everyone seems to say it's my ball joint..
thanks..
ps: already searched</TD></TR></TABLE>
Depends on which ball joint it is. If it's an outer tie rod, you can easily buy new tie rods w/ new ball joints included and install them yourself. You will need an alignment afterwards.
If it's the upper ball joint, sometimes you can get those replaced (need a hydraulic press), but other times you have to replace the whole control arm. Alignment is not totally necessary but wouldn't hurt.
For the lower ball joint, you definitely will have to get someone to press it out and press a new one in. If you remove the spindle to take it to a mechanic, then you have to separate all the other ball joints anyway and will need an alignment.
Old Feb 27, 2007 | 12:51 PM
MATiC's Avatar
anyone know how much, more or less, it would cost to get the lower balljoint replaced with a mechanic..?
dpkelly
16
Dec 29, 2023 07:19 AM
MK Ultra
Dec 7, 2006 01:06 PM
honda8882
Jul 8, 2002 08:19 PM
Spade
Jun 20, 2002 07:43 AM
