MARCH 07 - Wisconsin FS - FT - WTB Thread -- Wis for sale MAR
** Check this out **
Everything must go - TEIN SS Chipped ECUs JDM Parts Galore
https://honda-tech.com/zerothread?id=1910154
PM with any questions - No reasonable offer refused
Modified by Honda_Fanatic at 12:05 AM 3/2/2007
I know this is the wrong thread but EVERYONE COME TO THE CHICAGO/Midwest H-T MEET https://honda-tech.com/zerothread?id=1899452
Why the hell is a new thread needed every month? It took 3 weeks to fill 1 page in February. There's a general Wisconsin FS thread that works just fine.
http://www.hondamarketplace.co...37861
F/S Garrett TR0759 (t25) no shaft play doesnt leak any oil fins are all in good condition. looking to get 175 for it. pm me with your email for pics
last of the junk i have left over....
MSD Pro Billet distributor setp. Comes with dizzy, magnacore wires, coil, and ignition module. The dizzy is obd2 but i also have a MSD obd2-obd1 conversion harness as well. Best ignition setup you can buy!! -$350 for everything.
BRAND NEW Worldwide Alternator for obd0-obd1 b-series. Lifetime warranty as well from advanced auto parts. Also has aem pulley on it. $90
Mr. Gasket 68mm throttle body, comes with map sensor and gsr throttle bracket. You can use this on ALL b-series.... it has both holes on the throttle rotor so you can pull the cable with the gsr throttle bracket or from the other way with the bracket on the intake manifold. Mazworx also sells these on h-t -$200
Python 871xp paging alarm system. Also included are power door locks-$175
Keizer 2 piece forged aluminum wheels 13". Mounted on them are 24.5" x 8" Mickey's but they are completely worn. Weigh 7.5 lb's each. -$300 PRICE LOWERED to $250!
ARP pro flywheel bolts for b-series... bigger sized 19mm ones. $20
b20 crankshaft, spun a bearing needs to be micropolished or idk whatever you wanna do with it. $5
90-91 Civic/Crx drivers side headlight-$10
88-89 Civic/Crx passengers side headlight-$10
misc. tail lights-ones with slight crack are free. Good ones are $5 each
88-91 civic/crx main relay-$5
88-91 Civic/Crx Brand new beck/arnley clutch cable-$10
88-91 Civic/Crx winshield wiper arms-$5
88-91 Crx door speaker covers-$5
stock shift ****-$1
88-91 civic/crx gas pedal-$1
88-91 Civic/Crx radiator brackets-$1
88-91 Civic/Crx radiator support-$1
88-91 Civic Center vent-$1
88-91 Civic/Crx windshield wiper tank-$1
88-91 Civic/Crx coin tray-$1
88-91 Civic/Crx windshiled cowl-$1
Misc. cables (mostly throttle cables, i have a few different ones for newer integras etc-$5 each
88-91 Civic/Crx steering column with tilt-$5
b-series electric speedo sensor-$5
b-series hydro halfshaft-$30
(3) 99-00 B16 rear T brackets-$20 each
crome b-series upper timing belt cover-$5
b-series starter-$30
90-93 Integra front wheel hubs-$5
92-95 Civic front strut forks-$5
resistor boxes-$5 each
b-series alternator brackets-$5
2 1/2" 90degree intercooler pipe-$5
88-91 Civic/Crx raditor fan, 94-01 integra radiator fan-$5 each
newer intergra ac compressor-$5
jdm crx b-series power steering pump-$5
b-series vtec solenoid *missing spool* $5
b-series hydro clutch shift fork-$5
89-91 Crx drivers door glass-$20
88-91 Civic hatchback passengers quarter panel glass-$20
88-91 Crx rear bumper-$5
4 wire o2 sensor-$20
1 wire o2 sensor-$1
tekniq auto 88-91 civic/crx wheel hub for sparco steering wheels-$10
Not pictured but available-
complete 99 b16a2 swap-$1400
93-98 Supra tanabe catback exhaust-$300
WTB Gt42R turbo or bigger!
Located in Milwaukee. Parts MUST be picked up locally. For something thats worth $1 please don't ask me to ship it because i'd rather just toss it then go through the hassle. I will be willing to ship the more expensive items such as the dizzy,throttle body etc. But not the slicks. Please don't ask me for trades, i don't need anything but a gt42r or bigger turbo or parts for a mk4 supra. thanks
stock shift ****-$1
1 wire o2 sensor-$1
Hondata s200 no boost
H22 89mm endyne roller wave pistons 12/1comp.
90-97 accord F&R ST sway bars, and tokico full coilovers
accord forbiden short shifter
accord shifter lines
accord front calipers
H22 LSD M2B4 mint
used h22 ACT clutch and 11lbs flywheel
H23 Vtec engine: never ran, just back from the machine shop
h23 crank
h23 crower rods
Type S pistons
Skunk2 stage II cams
SK2 valve springs and retainers
SK2 cam gears
SK2 intake manifold
all new gaskets and arp bolts for all
Pics might take a week or two
H22 LSD M2B4 mint
h23 crank
h23 crower rods
Type S pistons
SK2 cam gears
SK2 intake manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Beaver »</TD></TR><TR><TD CLASS="quote">Why the hell is a new thread needed every month? It took 3 weeks to fill 1 page in February. There's a general Wisconsin FS thread that works just fine.
http://www.hondamarketplace.co...37861</TD></TR></TABLE>
cause that old *** thread has **** for sale from 2004. i still get pms asking if i'm still selling my old d16a6 from 2 years ago.
94-01 integra wing west side skirts, good condition, asking 90 bucks
94-01 4dr black euro chrome tail lights, mint condition, asking 45
94-00 stock hood, asking 25
92-95 civic/94-01 Drop Zone Racing Series Full Suspension, asking 450
92-95 civic hatchback JDM side skirts, brand new, asking 80 bucks
92-95 civic Ex Tach, broken temperature needle, replace it only. asking 50 also have yellow euro dash included
92-95 EX/SI manual indiglo for 20 bucks
96-00 civic hatchback/3dr black widow I side and back, good condition, primed white, asking 60 a piece or 100
both
96-00 buddy club rear lip for hatchback, good condition, silver, asking 70
99-00 SI cluster, with only 90k, make me an offer
brand new ADR rims 17'S SILVER/POLISHED LIP, with brand new tires. asking 650
17 ROTA Circuit 10's, BRONZE with 65% tires, one curbed(not that bad)about a inch, asking 600
16 ROTA Circuit 8's, BRONZE2 with 60%, other 2 is 80%, two has little curb rashes, asking 525
have only 1 set of center caps. some thieves sold the other set..cursed them all!
1 fat fives alloy, sprayed bronze, with 50% tread on tire
4 honda 14's steelies with only 200 miles on new tires, asking 150
2 brand new Nitto NT450 195/50/15, paid 140, asking 120
99 civic mint front seats, make me an offer
del sol front seat, Black with red stripe, rip on driver side seat, okay conditions, make me an offer
Autometer Phantom 5 Tach. mint condition, asking 100
both
http://www.hondamarketplace.co...10149
And 2 Preludes FOR SALE
1992 Prelude SI
http://www.hondamarketplace.co...01585
1992 Prelude S
http://www.hondamarketplace.co...1587
1992 Prelude SI
1992 Prelude S
1994 LS B18b swap. has around 100k on it. when i pulled out the motor run/drove perfect with no grinds runs very storng. comes with axles, shift linkage, LS hydro tranny, and motor moutns. $ 1000 throw me other offers need this gone pics will be up this weekend. IM me with questions i am willing to seperate engine and tranny.
1992 Prelude SI
1992 Prelude S
1992 Prelude SI
1992 Prelude S
WTB: EX/SI Transmission with NO GRINDS. Dont PM me if you dont have either an EX/SI tranny cuz I dont want them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice a roni »</TD></TR><TR><TD CLASS="quote">woot bumps looking for a beater pm me.</TD></TR></TABLE>
I have a 89 civic hatch if your intrested.
WTB: D16A6-must be in good condition
FS: EP3 Rims and tires
No curb rash. These are mint. They are a little dirty in the pics. Michelin tires do have some life left.
$500 OBO
Look in my sig for turbo stuff for sale aswell.
$500 OBO
