94 honda accord lx
ok trying to replace the flasher for my friend he said he has it.. okay i'm assuming the blinkers and hazard are one flasher.. well i think i located it.. its to the left of the clutch pedal right.. goes into the fuse box... well im having trouble pulling it out.. i tried wiggling it side to side.. theres like a little tab on each end i pushed it while pulling it out still didn't work.. whats the correct way.. thanks
I had the exact same problem with my 93 prelude.
Read the last post in the tread.
https://honda-tech.com/zerothread?id=1618020
i'm stillhaving trouble i see clips on each side but those doesn't pull the flasher out adn i don't see anything else that holding it in.. i tried wiggling it thanks.. help me someone..
quoted from the last post that I told you to read
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by profroopchan »</TD></TR><TR><TD CLASS="quote">
I had a hell of a time getting mine off. That is because I didn't know where the clips that clip it on were located. It has two clips to hold it on. One clip at the top, and one at the bottom. Just push a flat head screwdriver in both clips, and you will be able to pull it out. Disregard the clips on the side. Those are there to hold the unit together in one piece. I used a camera phone to video the top of the flasher so that I could locate the clip on the upper (top) surface of it.</TD></TR></TABLE>
I took forever to get it off. I went to the junk yard and pry it off with a screw driver. Only after seeing how it looks taken off did I figure out how to easily remove it from my car. I ripped up the clips on the sides trying to get it off, but the clips only holds the unit together.
ok its not the flasher swap it out.. hazard fuse on the fuse under hood is good.. all the light bulbs works.. funny thing is the hazard light will work along with the dash. but if u put the turn signals it doesn't show on the dash nor will it blink but hazard work.. only fuse i didn't check is kickpanel didn't try that because i don't think theres one.. plus theres no fuse panel so what should i look for.. i'll just pull out whatever amp u guys said it might be.. also try to give me direction where it could be located and number of amperage..
thanks
thanks
Are you sure its the same "Flasher" That I am talking about? The flasher that I am talking about is above the fuse box. When you take it out, it should be this big square thing, about the size of a cell phone when closed. Are you sure that the one that you swapped it out with worked? Did you get it from a working car? There were no stores that I could find that carried the flasher, and Honda wanted about $90 for it. I got it from a junk yard for $5.
