FS: Skunk2 valves
Hello TI.
I have 16 brand new skunk2 valves.
(16 total for the intake & exhaust side).
Still in package. One is sealed, the other i opened to take a picture of one of the valves.
They're for DOHC vtec engines--primarily for the GSR engine.
Here's a description of them from Skunk2 website:
Skunk2 Racing valves are made from SAE EV8 stainless one-piece forgings, which are then heat-treated using a proprietary heat treatment process. After CNC-machining and swirl polishing, a PVD black nitride coating is applied to reduce friction and increase wear resistance. Skunk2 Racing valves are lightweight, durable, and offer excellent heat and corrosion resistance. Skunk2 Racing valves are available in standard and high compression styles and also in various sizes. Oversized valves should not be used with standard size valve seats or with Stage II and III VTEC camshafts.
These usually go around $350 plus (not including shipping or tax--if buying from a shop).
However, i'm willing to let them go for $300 obo + FREE SHIPPING!
***I will be posting pics up tomorrow with a digital camera to get better resolution***
Thank you for looking.
Had mechanic look at them. He said they would fit with the stock pistons and not give any problems what so ever.
So, i'm pretty sure they're not oversized. They do add a little more compression than stock ones or itr valves.
Great for people with high compression motors or want to do rebuilds while you're at it.
I never installed because i was going to get charged more, i already spent $600+450 on parts & labor (cam install).
jDMJeRk
Feb 9, 2004 01:00 PM
