Do i need larger injectors?
Old Feb 26, 2007 | 08:14 PM
watsvtecEK's Avatar
Default Do i need larger injectors?
I am going to be running a b20b (non-vtec) crower 403's, after market valve springs (haven't decided which ones yet), adjustable cam gears, skunk2 intake manifold, with a chipped pr4 that i am getting tuned on crome. also i/h/e blah blah. i am wondering if the stock b series injectors will be good enough or should i go with some h22 injectors or some RC's? thanks in advance.
Old Feb 26, 2007 | 08:21 PM
b16nonoy's Avatar
Default Re: Do i need larger injectors? (watsvtecEK)
I believe those are 270cc's....I am running 310cc on my b16...
Old Feb 26, 2007 | 08:32 PM
watsvtecEK's Avatar
Default Re: Do i need larger injectors? (b16nonoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16nonoy &raquo;</TD></TR><TR><TD CLASS="quote">I believe those are 270cc's....I am running 310cc on my b16...</TD></TR></TABLE>
Yes but do i need larger injectors for my setup? or will stock b-series injectors flow well enough?
Old Feb 26, 2007 | 08:40 PM
MR.johnson's Avatar
240cc will do just fine on 93.
Old Feb 26, 2007 | 08:47 PM
watsvtecEK's Avatar
Default Re: Do i need larger injectors? (MR.johnson)
most pumps around here only have 91, sooo i want to make sure...
Old Feb 26, 2007 | 10:07 PM
b19coupe's Avatar
Stock injectors will be adequate.
Old Feb 27, 2007 | 11:38 AM
EnjoyTheRideDC2's Avatar
B series injectors will be fine. What you may want to invest in is a FPR and Gauge before you even get into picking up injectors. Without at least an FPR, larger injectors wont do you any good.
Old Feb 27, 2007 | 11:40 AM
gibsanez's Avatar
Default Re: Do i need larger injectors? (EnjoyTheRideDC2)
Are FPR's really that necessary when he's getting it tuned anyways?
Old Mar 1, 2007 | 09:43 PM
watsvtecEK's Avatar
Default Re: Do i need larger injectors? (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">B series injectors will be fine. What you may want to invest in is a FPR and Gauge before you even get into picking up injectors. Without at least an FPR, larger injectors wont do you any good.</TD></TR></TABLE>
i am tuning on crome so i dont need a fpr, anyway i picked up a set of h22 injectors today.
Adi_King
Jun 29, 2015 08:02 AM
crowder13
Mar 31, 2007 02:56 PM
cmyrex
16
Oct 13, 2005 05:38 PM
AzNpRiD3
Oct 28, 2004 06:35 PM
shermanyang
Jun 17, 2002 01:29 PM
