Speedo/CEL problem
Old Feb 26, 2007 | 07:12 PM
1.6 vtec civic's Avatar
Default Speedo/CEL problem
Ok here is my problem. I have a 93 prelude with a jdm H22a swap, and every once and awhile while i'm driving the speedo will drop from speed to zero and sit then on and off work and not work. Also sometimes(rarely) when the speedo die like above the CEL turns on but if I stop, turn the car off and back on the speedo works and the CEL turns off. What could the problem be?
Also no I don't have what code the CEL threw. Also thank you in advance for your help.
Old Feb 27, 2007 | 08:43 AM
Default Re: Speedo/CEL problem (1.6 vtec civic)
Bump
Need help with this.
Old Feb 27, 2007 | 08:45 AM
rawNArsxS's Avatar
i used to have the same problem...its the vss
Old Feb 27, 2007 | 11:33 AM
Default Re: Speedo/CEL problem (rawNAprelude)
I'm sorry i'm not familiar with all of the abbreviations, what is a vss? Is it a pretty painless fix or is it a bigger project?
Old Feb 27, 2007 | 11:45 AM
MLBZ521's Avatar
It's the Vehicle Speed Sensor. It's on the Tranny. I couldn't tell you how hard it is, but shouldn't be to complicated.. But I haven't changed/removed one, so I can't tell you for sure..
Search for VSS related Topics and you should find something about them.
Old Feb 27, 2007 | 01:06 PM
Default Re: Speedo/CEL problem (MLBZ521)
Thanks for your guys help.
Old Feb 27, 2007 | 08:44 PM
rawNArsxS's Avatar
its a friggin pain in the ***. its in an awkward spot to get to. it would be much easier to do if the tranny was out. however it can be done with it still in the car.
Old Feb 27, 2007 | 09:01 PM
piggydog's Avatar
yeah it's a real pain in the *** to get to. Right below the throttle body on top of the tranny. You've got to take a lot of stuff off before getting to it.
Old Feb 27, 2007 | 09:22 PM
rawNArsxS's Avatar
Default Re: Speedo/CEL problem (piggydog)
not really...just the intake pretty much. thats all my old boss n i moved
DiegoAdonis
Apr 17, 2014 10:49 AM
loveO
10
Jul 24, 2009 06:09 PM
1sickek187
May 31, 2009 07:54 AM
92SleeperH23
Jul 13, 2005 07:07 PM
diluted
Dec 23, 2004 05:12 PM
