Question about wheels/suspension...
Old May 21, 2002 | 11:47 AM
Si's Avatar
Si
Default Question about wheels/suspension...
I resently bought new wheels and the original wheels were 195/55/15, the new ones are 205/50/15. Since the wheels stick out a bit, if I lower the car would I have to change the camber to prevent the tires from rubbing against the fender?Thanks
Old May 21, 2002 | 12:17 PM
94CivicSi's Avatar
Default Re: Question about wheels/suspension... (RedSi99)
No. What wheels are those? Looks like a high offset for Honda.
You might rub in the rear depending on the tires you run. Azenis guys some to have a lot of rubbing problems as the tirees are unusally wide. Start by pulling off the black rubber trim on the inside of the fender. If they still rub, you can roll the lip inside the rear fender. Never had a problem in the front.
ennohohbee
Mar 12, 2014 05:42 PM
zachkiro
Honda Civic (2001 - 2005)
10
Oct 29, 2008 04:44 PM
bigdaddyjimmyjam
Aug 8, 2006 06:49 PM
zenon8890
18
May 5, 2006 03:13 AM
743power
Feb 19, 2006 05:04 PM
