98 H22 swap in 95 NON vtec question
Old Feb 26, 2007 | 06:45 PM
turb0hatch04's Avatar
Default 98 H22 swap in 95 NON vtec question
i have a 95 prelude OBD1 and i have a 98 H22 swap that i want to put in there. i have ecu, dizzy and all that but i dont have the 98 H22 wire harness. i was wondering if i can use the OBD1 non vtec wire harness on the H22 and i can just wire up the vtec myself but what kind of problems am i going to run into. also can i repin the obd2 distributor for OBD1? any help would be appreciated and thanks in advance.
Old Feb 26, 2007 | 06:53 PM
md23vtec's Avatar
Default Re: 98 H22 swap in 95 NON vtec question (turb0hatch04)
Use the wire harness in the car already. Wire vtec pressure and vtec sol. 2 simple wires and your done. Just get obd1 P13 (prelude vtec ecu) and obd1 H22 injectors its a simple swap goodluck
Old Feb 26, 2007 | 09:10 PM
Honda_Fanatic's Avatar
Default Re: 98 H22 swap in 95 NON vtec question (md23vtec)
I would get an OBD 1 dizzy as well. It has the crank sensor built in and will be much easier. I have one if your in need. email me derekburress@yahoo.com
Old Feb 27, 2007 | 06:04 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">Use the wire harness in the car already. Wire vtec pressure and vtec sol. 2 simple wires and your done. Just get obd1 P13 (prelude vtec ecu) and obd1 H22 injectors its a simple swap goodluck </TD></TR></TABLE>
Werd. Use the OBDI wiring harness and all OBDI items like fuel rail, injectors, distributor. On the a4 block, there's a connector down by the oil pan that is the crank position sensor. If you use the OBDI distributor, you don't have to wire that one in. Just ziptie it out of the way, or remove altogether.
If you're lucky, one of the VTEC wires is already wired in, check the passenger side harness for a connector that isn't connected to anything. I belive it's a green/yellow wire, with a single input connector. It might be covered with an orange rubber cover.
Old Feb 27, 2007 | 03:16 PM
is there any way i can repin the obd2 dizzy to obd1. im not too sure about the prelude's but on my b series i got a obd2 dizzy repinned for obd1
Razzjam
Mar 17, 2016 11:17 PM
H22LUDE808
Jun 18, 2008 09:10 PM
blu_ej
Apr 8, 2008 07:52 PM
lsturboguy
Jun 3, 2007 01:02 PM
