FS In New Jersey - One Very Sick Supercharged Integra
Old Feb 26, 2007 | 06:33 PM
KingKash420's Avatar
The OG Animated Avatar
Default FS In New Jersey - One Very Sick Supercharged Integra
ASKING PRICE IS NOW $9,000 I WANT THIS CAR TO GO TO A GOOD HOME!
Well guys the time has come to sell my integra.. this car has been my pride and joy for almost 3 years now and it consistently gets looks from everyone wherever it goes. Unfortunately the car is no longer realistic for my needs. I recently became a real estate agent and the time has come to trade in my 2 door coupe for a more refined 4 door sedan. This 2 owner car has been babied since I took ownership of it, and the previous owner was an absolute fanatic about the car. There is so much time and money invested into this car it is ridiculous. Almost every maintenance part on the car has been recently replaced from the water pump and timing belt, to the brakes rotors and brake lines, to the wheels and tires, to the dizzy cap rotor and wires. I know this car is going to make the next owner as proud of it as it has made me.
The Car has 44,305 original miles and a clean car fax!
1999 Milano Red Acura Integra LS B18B1 motor
Performance Upgrades:
-'98 Ls head with ported/polished/shaved .0015
-Crower titanium springs/retainers
-Crower stage 2 60203 intake cam
-Clutch Masters 12lbs. lightened flywheel
-Clutch Masters stage 3 full Clutch assembly
-Jackson Racing polished and engraved cam seal
-Jackson Racing 160 degree F* Thermostat
-Jackson Racing Super Charger running 7 1/2 psi Boost w/ B20 crank pulley
-Kamakazi 4-1 Ceramic header with custom 2.5" flange
-Flowmaster 2.5" race cat w/ flex mesh pipe connectors
-Greddy Evo full Catback exhaust
-Iceman Intake custom cut for JRSCer and Black heat coated
-Giant K&N Air Filter
-Distributor King Dizzy With Lifetime Warranty
-MAGNECOR Race Wires
-NGK R5671A-7 Spark Plugs
-Brand New OEM Waterpump
-Brand New OEM Timing Belt
-Brand New OEM Belt Tensioner
-AEM Red 2 cam gears
-AEM Red Power steering Pulley
-AEM Red Fuel Rail
-AEM Red Fuel Filter housing
-AEM Red Fuel Pressure Regulator
-B&M Oil cooler and filter relocation kit (mounted 100%, Just needs to be connected)
-OBD II to OBD I Kenji conversion harness
-OBD I P28 ECU chipped for 440cc injectors
-Hondata 2b on board engine management box
-RC Engineering 440cc injectors
-Deleted rear windshield wiper
Outside:
-Wings West 3 piece mid wing w/ shaved antenna hole
-Acura OEM 5 piece body/lip kit Factory painted
-Fuba-D short roof mount antenna
-Fiber Images Red/Black carbon fiber/Kevlar OEM style hood
-Clear w/ black housing front corner lenses
-Hella Fog Lamps
-Stock OEM '99 All Red taillights
-L.E.D Bulbs all the way around out side lights
-Slyvania Silverstar 9005 Conversion For Lowbeams
-15% limo tint on rear side and rear windows
-JDM Red "H" emblems front & back
-JDM "HONDA trunk emblem
-Amber lense side marker lights
-Brake calipers heat painted Red
Inside Upgrades:
-Autometer Integra Dash bezel for 2count 2 1/16th" gauges
-Autometer Boost gauge
-Autometer Air/Fuel L.E.D stoich meter
-Greddy silver Turbo/N.A. Timer
-B&M Race Spec Short shifter kit w/ Energy Suspension red polyurethane bushings
-Black/Gray traditional 21 piece carbon fiber dash kit
-Carbon Fiber Shift ****
-JDM ITR Black leather w/ Red stitch Shift boot
-Red/Black Sport pedals w/ matching dead pedal
-Ignited Red Push Start button in place of cruse control ( not hooked up !!!)
Wheels/Tires/Brakes/Suspension:
-17x6.5 Black JDM Nippon Racing Wheels wrapped in 205/45/17 Cooper Cobra Tires 95% tread left on tires
-Irotors Zinc Plated Slotted And Crossdrilled performance rotors
-Goodyear Stainless Steel Brake Lines
-Axxis Metalmaster brake pads
-Omnipower Street Rate Coilovers
-KYB AGX. Adj. 4 way Shocks
-DC Sports rear lower polished tie bar
-Neuspeed front upper 4 point strut tower bar
-JDM Do-Luck* polished back seat floor chassis bar
-Suspension Techniques 24mm front lower Sway bar w/ Poly. Energy Suspension Red Endlinks and D-bushings
-ITR 23mm rear lower sway bar
-ITR trunk rear deck frame bar
-DIY 95-96 JDM SiR-G Gold fog lights installed
-DIY Gold DRL (daytime running lights)in the high beam housings).
-DIY tubular 1" rear seat delete brace, custom made and installed.
Car Audio:
-Pioneer Headunit
-Stinger Platinum battery cable connectors +&-
-Stinger Amp wire kit including 60 amp fuses, Max wattage that can be run= 1400 watts
-2 Rockford Fosgate power distribution blocks, "one mounted in engine bay, one mounted in trunk near amps"
-2 Pioneer 4-Way 100 Watt Speakers Mounted In Front
-2 Kicker tweeters mounted outside of the A-pillar
-2 stock mounted Acura based tweeters w/ bass blockers installed
Car Security:
Black Widow - BW Z5 FULL FEATURED SECURITY SYSTEM WITH REMOTE START
My Asking Price Is $9,000 willing to work on the price with a serious buyer but not by much this car has over $15,000 in upgrades and that is not counting dyno time and tuning..
My Name Is: Joe
My Number Is: 732-682-3661
My Email Is: KingKash420@optonline.net
Modified by KingKash420 at 10:57 PM 4/16/2007
Old Mar 1, 2007 | 05:12 PM
shocker979's Avatar
PM'ed ya, LMK
Old Apr 16, 2007 | 06:58 PM
Bump
Old Apr 18, 2007 | 12:38 PM
Outkasted24's Avatar
Default Re: (KingKash420)
Bump
Cabby89
Aug 16, 2007 09:02 PM
bonta-kun
Jun 17, 2007 08:58 PM
bonta-kun
May 5, 2007 11:44 PM
KingKash420
Northeast (Sales)
12
Apr 16, 2007 06:59 PM
bonta-kun
Feb 25, 2007 02:01 PM
