How Do i remove my Clutch??**and yes i searched**
Old Feb 26, 2007 | 05:12 PM
Under Con. CrX's Avatar
Default How Do i remove my Clutch??**and yes i searched**
ok i can seam to figure out how to remove my whole clutch assy.i know i have to take of the 6 bolts on the pressure plate but what i dont know is how do i stop it form rotating when i go to losen it turns over what can i do or what do i have to do in order to stop this form happening?? thanks guys
Old Feb 26, 2007 | 05:17 PM
Default Re: How Do i remove my Clutch??**and yes i searched** (Under Con. CrX)
please i need help
Old Feb 26, 2007 | 05:24 PM
Crx Jimmy's Avatar
if you use a air gun you dont have to worry about that. the flywheel bolts are the only ones that are real tight. the pressure plate bolts are not very tight since they are small if they are tightened to much they will snap, just let the motor rotate till it gets to a compression stroke and you should be able to get them off with hand tools
Old Feb 26, 2007 | 05:30 PM
Default Re: How Do i remove my Clutch??**and yes i searched** (Crx Jimmy)
ok thanks for your help
B16-CRX
Transmission & Drivetrain
Feb 18, 2011 04:34 AM
slowassciv33
Aug 23, 2006 08:20 AM
civic_driver
Nov 9, 2005 11:54 AM
JDMCivicEF9
Apr 20, 2005 05:36 PM
stRtypR25
Dec 20, 2002 10:49 AM
