wire colors for keyless entry
I am installing a keyless entry on my 1995 honda accord. i was planning on just soldering the rubber off of the necessary wires in the harness under the dash, wrapping the wires for the keyless entry around their corresponding wires under the dash and putting a bit of solder on to hold it (there is not enough room to cut and splice without me being very nervous lol). i'm pretty sure i've found the correct wires, but i just want to make sure because there are a ton of wires under there, more than i've seen in any other car i've worked on and the wiring chart i got online was very vague. what are the colors for the door lock, the door unlock, and the headlights? Also, will the headlights only flash when i lock it when the lights are on? if so how do i make them flash when i lock it even when the lights are off?
thanks
thanks
Dang i agree with you a 100% those wiring set ups that you get from the keyless and alarm systems are real broad they act as if all wires in every car are the same color. On the lights flashing twice that might be just the matter of a wire being off but it all depends on what type of system you got.
