Which ECU...
Old Feb 26, 2007 | 03:38 PM
The Collin's Avatar
Default Which ECU...
Will i need when converting a 99 CX to VTEC? I'll admit, i'm too lazy to search, and quite busy, so thanks if you help, poop on ya if you flame
Old Feb 26, 2007 | 03:42 PM
cambopheonix56's Avatar
Default Re: Which ECU... (99_hb_on_air)
What block are you using? What head?
Old Feb 26, 2007 | 03:49 PM
The Collin's Avatar
all off a y8, i believe.
Old Feb 26, 2007 | 03:53 PM
Default Re: (99_hb_on_air)
y8 block and head?
Old Feb 26, 2007 | 03:56 PM
The Collin's Avatar
y7 block, y8 head. about to just add vtec, so the head will be the only addition, plus ecu and wiring. block will be the same.
**DOHC HaTcH**'s Avatar
Default Re: (cambopheonix56)
rub some vtec juice on it and your good to go
Old Feb 26, 2007 | 03:57 PM
Default Re: (**DOHC HaTcH**)
Use the y8 ecu.
Old Feb 26, 2007 | 03:59 PM
The Collin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by **DOHC HaTcH** &raquo;</TD></TR><TR><TD CLASS="quote">rub some vtec juice on it and your good to go </TD></TR></TABLE>
sure, right after you go play in traffic.
Chris0619
Dec 1, 2013 04:15 PM
Edwin JDMJUNKIE
Dec 23, 2009 08:13 PM
96electronH
Oct 1, 2007 08:13 AM
