Removed head, do i need to do a valve adjustment and adjust the timing?
Old Feb 26, 2007 | 03:12 PM
boomersz's Avatar
Default Removed head, do i need to do a valve adjustment and adjust the timing?
just like the title says, removed the head to install arp head studs, new timing belt, pump and tensionor, cap and rotor. do i need to do a valve adjustment and re- adjust the timing?
Old Feb 26, 2007 | 05:05 PM
Mikey3000's Avatar
Default Re: Removed head, do i need to do a valve adjustment and adjust the timing? (zoo)
you don't NEED to but its probably a good idea since you have it apart. and yes you need to re-adjust timing as well, especially if you pull the dist. off.
Old Feb 26, 2007 | 05:14 PM
boomersz's Avatar
Default Re: Removed head, do i need to do a valve adjustment and adjust the timing? (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">you don't NEED to but its probably a good idea since you have it apart. and yes you need to re-adjust timing as well, especially if you pull the dist. off.</TD></TR></TABLE>
Well it's already all back together, but I just thought I had to
Old Feb 26, 2007 | 06:10 PM
accordking's Avatar
adjust timing already.
Old Feb 26, 2007 | 07:37 PM
boomersz's Avatar
Default Re: Removed head, do i need to do a valve adjustment and adjust the timing? (accordking)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordking &raquo;</TD></TR><TR><TD CLASS="quote">adjust timing already. </TD></TR></TABLE>
is there anyway to do it without a timing light or atleast really close so i can drive it around for awhile?
Old Feb 27, 2007 | 09:54 AM
B18C_EJ8's Avatar
Just eyeball it. You'll be fine.
Old Feb 27, 2007 | 11:38 AM
gibsanez's Avatar
Default Re: (B18C_EJ8)
Setting valve-lash is easy and should take 10 minutes with some feeler gauges.
BUDtoker
20
Nov 6, 2007 10:25 AM
98tegLSvtec
Jul 31, 2007 02:54 AM
boomersz
Feb 26, 2007 07:41 PM
White86CRXSi
Aug 27, 2004 03:19 PM
wizzards581
May 15, 2004 10:55 PM
