Dyno'ed my 2000 Integra GSR sedan B18C... Terrible numbers
Stock 2000 Integra GSR Sedan with JDM B18C with a Password JDM whale ***** intake
My first run was around 128 HP
with stock intakeMy second run was around 130 HP
with stock intakeMy 3rd run is the dyno sheet above
... I put 91 octane... The previous owner said he did a tune-up on it... It drives fine and everything... The numbers are horrible.. Any idea ? I had a check engine light 3 weeks ago while driving on the freeway and I didn't get a chance to run the code because the guy who did my alarm unhooked my battery but the car drives fine. I posted on HT and both replies were O2 sensor , could that be it ?
Help out a newbie
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundFX »</TD></TR><TR><TD CLASS="quote">it is a sedan which mean its heavier </TD></TR></TABLE>
That has nothing to do with his numbers on the dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundFX »</TD></TR><TR><TD CLASS="quote">it is a sedan which mean its heavier but i thought u would get better numbers. interesting</TD></TR></TABLE>
The dyno is static. Weight has nothing to do with it.
dude i ran better numbers in my ls...something ain't right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomithy »</TD></TR><TR><TD CLASS="quote">Those numbers are at the flywheel too? Wow...</TD></TR></TABLE>
no that's a dynapak chasis dyno, same as a dynojet i'm pretty sure. the kind with rollers.
edit: my bad it's the one that hooks up to your rotors....but those numbers should still be way higher then they are.
If I'm not mistaken, Dynapack does hp numbers to the wheels. When I did my dynoes, the tuner told me that although it says crank hp, it is wheel hp.
120.3 tq/153.8hp with i/h/e/head redone/sk2 sgt1 cams/intake manifold/injectors/tuned
I have to replace the piston rings. Dyno is about 5% off of what a dynojet would show.
I don't mean to steal your post. I just want to show you that your dyno isn't all that bad for a stock engine +intake.
O2 sensor does not control WOT fuel delivery, so it's not the problem.
The numbers are not horrible, but dissapointing. Considering the condition of the engine and correction factors you can make sense out of those numbers....
Yeah he said get an intake / jdm 4-1 header / catback I should see 140-150 ..
Doesn't matter .. Something is seriously wrong.. its a jdm b18c not the stock b18c1.. I should see 140-150 stock no mods.
Like I said , it drives perfectly fine. I'll get a compression test done when I have time.
Doesn't matter .. Something is seriously wrong.. its a jdm b18c not the stock b18c1.. I should see 140-150 stock no mods.Like I said , it drives perfectly fine. I'll get a compression test done when I have time.
I made 144whp when i dynoed with i/h/e i think my timing was a little retarded though. I think it also depends on what kind of dyno it is. Check your compression and timing b/c 128hp is pretty low for a gsr.
horrible numbers especially with jdm engine. maybe your pipes and tubes are filled with carbon residue causing things to not flow efficiently.
Sooo no one has mentioned this yet, but where is the A/F readout on that chart? We need to see the A/F as well to help figure things out. Checking the compression, leakdown, and getting the A/F chart will help a ton.
