Help removing resistor box.
whats up everyone? I have aquired a 90 dx hatch with a jdm d15 awhile ago and now I am just getting into the wiring for the car. My issue is the car was converted from obd1 to obd0 by the previous owner. I figured I would clean it up and do it the right way. i have the OBD1 dizzy wired up, and the injector clips are busted on everyone of the injectors so I am replacing the injectors and the plugs with good obd1 plugs. I need to figure out when i cut the resistor box out, because it was just butt connected, where do the yellow with the black stripe wire into on the car? here are a few pics.
New plugs
Where do these wires go when I take out the resistor box?
Thanks for the help.
New plugs
when you remove the resistor box you just twist the 5 wires that came out of it together. i had a picture of it but i dont know were it is now.
ps you could have found your answer using the search.
levi
levi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRinmyCRX »</TD></TR><TR><TD CLASS="quote">when you remove the resistor box you just twist the 5 wires that came out of it together.
levi</TD></TR></TABLE>
you can solder them together if you would like
hybridpatient95
19
Oct 2, 2005 07:35 PM
Steve91
Sep 4, 2003 08:22 PM
