Need Customization Advice!!!!
I'm getting so stressed out with this damn situation! I've heard that people swap out the factory 6 1\2's for 6x9's and i got my 6x9's and my lil 4 channel and now i cant figure out how its done... where do i cut? what tools will i need? i also have MTX 8's Would they fit? i dont want to take them out of the box to test... please let me know... I Drive a 1994 Civic EX Coupe 2Dr. I've posted this like 3 other times and no one has even responded.... which is odd because this site is where i got the idea. but anyway i appreciate it, thanks.
I have not seen it before, but My advice is the same as B18C_EJ8 not worth it, a properly installed 6.5" will outperform an improperly mounted 6x9.
Another problem is the rear deck of your car is structural all the dimples, folds and ribs are there for a reason, cutting them out only weakens the chassis in the rear leading to leaking rear window and other problems.
Swap the 6x9s for a set of 6.5", install the 8" into a box, use the HU to run the rear 6.5" and 2 ch. of the amp for the front 6.5" and bridge the other 2 ch. and use them to drive the 8", you will end up with better sound and without cutting up your car.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vaw7er »</TD></TR><TR><TD CLASS="quote"> I'm getting so stressed out with this damn situation! I've heard that people swap out the factory 6 1\2's for 6x9's </TD></TR></TABLE>
just because some people do it, it does not mean its a smart idea. what are you trying to accomplish by doing all of this work? is it just to be different?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">Putting 6x9" or 8" speakers into the rear deck designed to accomodate 6.5" speakers is not worth the time & effort IMO. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">I have not seen it before, but My advice is the same as B18C_EJ8 not worth it, a properly installed 6.5" will outperform an improperly mounted 6x9.
Swap the 6x9s for a set of 6.5", install the 8" into a box, use the HU to run the rear 6.5" and 2 ch. of the amp for the front 6.5" and bridge the other 2 ch. and use them to drive the 8", you will end up with better sound and without cutting up your car. 94 </TD></TR></TABLE>
venomousracin
Audio / Security / Video
Nov 20, 2010 02:20 PM
