altenator Q
Old May 21, 2002 | 10:26 AM
SuperJay's Avatar
Default altenator Q
OK so I'm almost ready to put my B16 in, I was wondering if I could use my ZC altenator since it's brand new. It' looks like it would work and the one that came with the B16 has a bent pully . If anyone knows if this'll work, let me know. Thanks
[Modified by SuperJay, 7:26 PM 5/21/2002]
Old May 21, 2002 | 10:37 AM
SuperCivic's Avatar
Default Re: altenator Q (SuperJay)
i'm don't think it will cuz the ZC is a d-series component, while your motor is a b-series. when i replaced mine i used the alternator from a 91 integra and it works fine..
Old May 21, 2002 | 12:36 PM
OneB16's Avatar
I need to replace my alt. here now and talking to people I found that my D series would not work on the B16A.
-Nic
Old May 21, 2002 | 12:54 PM
WuShu's Avatar
New User
Default Re: altenator Q (OneB16)
im using a b16a alternator on my sohc zc, look at the plug on the alternator mines had 4 prongs on it. check your motor and then check the alternator, if it matches itll work. but good luck finding a belt for it the pulleys are diff.
Old May 21, 2002 | 01:26 PM
SuperJay's Avatar
Default Re: altenator Q (HondaCRX)
plugs are the same. I figure it'll work. I could probably change brakets if I have to.
Old May 21, 2002 | 02:35 PM
dumbchild's Avatar
I'm running my 88 crx alternator on my B18 - the upper bracket doesn't match up but it works
ghost_ryder35
Aug 9, 2005 10:27 AM
Kampfer
May 4, 2005 12:37 PM
JapJunkie
Jan 18, 2005 09:56 AM
popngen
Jun 18, 2004 09:20 AM
WuShu
Jul 15, 2001 12:52 PM
