My B16 swap
i had my boy do a full dpfi to mpfi wiring harness on my car, which he did a great job on. it was made originally for my b18 which i ended up selling for a good feal on my b16. i juyst dropped hte bad boy in and i read up on a million and 1 articles about how to wire vtec. kuz my boy is out the country and i dont wanna wait. so i did exactly what it told me to do i ran wires to a4 and b5 i believe for the pressure switch and solenoid. i did not run a second o2 sensor because headers do not have one and i did not run a knock because i am odb0. my question is...... this is my first vtec swap and ive never driven a vtec car alhave been non vtec so how would i kno if its kicking in or if my vtec is working properly? just incase ur wondering i did not tap into the wires on the ecu ikut dem completely and sotord and heat shrinked the ones for the solenoid n pressure swich......
you need to wire the knock sensor also..and the 2nd o2 sensor is neccesary for the obd0 vtec ecu,otherwise it will throw codes and there will be no vtec...atleast run the o2 sensor wire and splice into the 1,,thats not the right way but better then throwing a code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExclusiveCRX »</TD></TR><TR><TD CLASS="quote"> how would i kno if its kicking in or if my vtec is working properly?</TD></TR></TABLE>
you'll know.
you'll know.
i c where ur comin from but they r type r headers and if i splice into it it will def throw a code, right now its not throwing off n e codes and i have 4 other boys who r driving around their obd0 cars without 2nd 02 and without knock, with no probs, its jus dat dey paid to get there cars done kuz otherwise i would have asked them for help.
ill, know? its funny u mention that kuz every1 says the same but im jus hopin dat the wiring diagrams i got n wat i did was good... i guess ill dinf out in a day or 2 jus waitin for intake and den im on da road.
im hoping my wiring was good and i guess ill find out when i take it out for a ride because right now i have no intake, ive had 2 people come to my car after its been running for about 10 mintues and rev all the way to red line and both have told me that i was poping vtec but i really couldnt tell what the hell they were listening for
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExclusiveCRX »</TD></TR><TR><TD CLASS="quote">im hoping my wiring was good and i guess ill find out when i take it out for a ride because right now i have no intake, ive had 2 people come to my car after its been running for about 10 mintues and rev all the way to red line and both have told me that i was poping vtec but i really couldnt tell what the hell they were listening for</TD></TR></TABLE>
you cant go into vtec in nuetral..your friends dont know much about hondas,you should keep them away from your car..
like i said before, you wire in 2nd o2 sensor,and knock sensr,then reset the ecu so the codes disappear and vtec will kick in as long as the engine is warmed up and you're going more then 20mph,,do research on how vtec works. specifically the b16a 1st obd-0
also for hearing the vtec watch this video,,its a stock b16 with a muffler,you'll hear that click,,thats the vtec solenoid and high cam switching over..http://videos.streetfire.net/v...c.htm
Modified by honda89crxsi at 3:01 PM 2/26/2007
Hondamonster
Jun 6, 2007 08:04 PM
new06member
May 30, 2006 07:30 AM
