drum brakes TO disk brakes ! HELP !
Old May 21, 2002 | 10:10 AM
fEAR9's Avatar
Default drum brakes TO disk brakes ! HELP !
i got a 94 civic hb dx , and i really have to get rid of those damn drum breaks... can some one tell me what i need AND HOW TO DO THIS !! AND ABOUT HOW MUCH IT WILL COST !! THANKS !
Old May 21, 2002 | 11:21 AM
moyerek's Avatar
Default Re: drum brakes TO disk brakes ! HELP ! (fEAR9)
you need 94+ teg rear trailing arm assembly with the e-brake cables and brake lines(rubber). I did a set a couple of years ago and they ran me $50 a side(from a honda junk yard) and then I got new pads and rotors. I think it cost me like $200 all said and done. Watch out though cause if you need new calipars they run like $80 a side. I can't remember if the stock(civic) rubber brake lines will work. I just used the teg lines cause they were on my assembly and were in good shape.
Old May 21, 2002 | 01:33 PM
MrFatBooty's Avatar
Default Re: drum brakes TO disk brakes ! HELP ! (moyerek)
You can also use the trailing arm/hub/brake assembly from a '92-'95 Si hatch or del Sol Si or VTEC.
Old May 21, 2002 | 03:32 PM
jaje's Avatar
if you do lots of drag racing then drums in the rear are better b/c they weigh much less...less weight means lower times
Old May 21, 2002 | 04:45 PM
moyerek's Avatar
It will be a lot easier to find a teg set-up unless you got a honda/acura junk yard around you. I got a nice honda junk yard near me and they don't got any del sols, but the got about a million integras. And any junk yard guy knows what a Integra is.... when you start talking trim levels, Vtec, si, etc. you loose them.
Old May 21, 2002 | 06:00 PM
Doctor CorteZ's Avatar
dont forget the non abs teg master cylinder booster and prop. valve to maintain the same pedal travel after the disc swap is done
honda_guy_07
Oct 21, 2009 04:08 PM
BatLude
Suspension & Brakes
Aug 14, 2006 09:26 PM
wilkerson05
Suspension & Brakes
Oct 16, 2005 06:00 PM
silverCRXTC
10
Oct 20, 2003 03:36 PM
WHATS VTEC
Dec 30, 2002 04:34 PM
