Can I use a DA Integras lower control arm?
I was just wondering if I could use the DA integras LCA to be able to put the newer type of shocks as apposed to the crx stock shocks because i'm gonna be doing the rear disc brake conversion? And if there's anything thing else I have to know please tell me.
geometry is bad. theyll fit, but you dont want the changes that will occur.
use 92-95 eg rear lca if you really cant get ef lca. theyre pretty much identical.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak »</TD></TR><TR><TD CLASS="quote">why not just get the function7's?</TD></TR></TABLE>
LOL...werd why don't you spend $300 for some rear LCA's?
Tyson as usual hit the nail on the head with the appropriate answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FIGARILA »</TD></TR><TR><TD CLASS="quote">
Tyson as usual hit the nail on the head with the appropriate answer.</TD></TR></TABLE>
wellll... if u know where to look they are only 250....
oh yea... & i WILL spend the money for them so back off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BackYardTuning(818) »</TD></TR><TR><TD CLASS="quote">I was just wondering if I could use the DA integras LCA to be able to put the newer type of shocks as apposed to the crx stock shocks because i'm gonna be doing the rear disc brake conversion? And if there's anything thing else I have to know please tell me.
Hold up now. Only the '88 CRX's have the stamped rear LCA. Just get '89-'91 EF LCAs. Should be hella easy to find.
</TD></TR></TABLE>Hold up now. Only the '88 CRX's have the stamped rear LCA. Just get '89-'91 EF LCAs. Should be hella easy to find.
I have 2 sets of si arms with sway bar holes. One set has pretty new poly bushings, the other set needs bushings(I have a new set of poly not installed as well) make an offer if you need them.
the top ones are 88 civic and crx only. 89-91 had the lower arm. they are the same performance, just different shock mounting.
just find some 89-91 control arms, or 92-95 civic ones if you want. junkyard, classifieds, whatever. new ones are about $140 for the pair from online dealers, iwth new bushings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BackYardTuning(818) »</TD></TR><TR><TD CLASS="quote">Mine look like the ones on the top. What car is the bottom one off of? And thnks for the help
Tyson is right. '88s are the stamped (top pic), and '89-'91 are the cast (bottom pic). Both are Civic/CRX rear LCA's.
And if you want to run the suspension techniques (or possibly others) sway bar, you'll definitely want the '89-'91 (cast) LCA's. Any junkyard will have them.
</TD></TR></TABLE>Tyson is right. '88s are the stamped (top pic), and '89-'91 are the cast (bottom pic). Both are Civic/CRX rear LCA's.
What if I got the LCA's off of a Honda Del Sol? Would it still work the same? Would this be better than using the DA LCA's?
Alright thnks
Just one more ? would it matter which model EF 89-91 I would get the LCA's from or just as long as its in that year range?
socalrex88
Jul 11, 2007 08:27 PM
JDMThoughts
Mar 21, 2005 03:41 PM
MikeySpec
Jun 16, 2004 03:48 PM
