H22a into a 94 Integra LS - Just a few questions - Need clarification
Old Feb 26, 2007 | 06:44 AM
Honda_Fanatic's Avatar
Default H22a into a 94 Integra LS - Just a few questions - Need clarification
I know that this is the same as the EG swap in the FAQ, but I am having a hard time weeding through the 100+ pages of comments, discussion and BS in that thread. I just have a few questions that I am hoping you all can help me out with.
1. I want to keep PS. What do I need exactly to do so? 97-01 pump and nothing else? Lines? Brackets?
2. I want to keep AC. What do I need to keep it? LS compressor? H22 Compressor? What lines? Brackets? Do I use the stock Radiator and fans?
3. I already have AVID mounts, are these any good? What should I expect from them?
4. I am using self made custom mounts with 90-93 Teg outer and 92-96 Prelude outers. Is that correct?
5. I am going to use the stock LS harness and modify it for the H22a?
6. I have to drop the car over the engine?
7. I have to trim the passenger tranny mount?
8. Rather than adding a resistor box for the Injectors could I run the H22a4 injectors instead? (they don't require a box) I would just have to change the LS injector plugs for the H22a4 injector plugs right?
9. I am running a chipped p28 so it will get tuned on crome
10. Is there anything I am forgetting here? Any advise recomendations would be great.
Thanks everyone for your help and please bump this if you read it.
Old Feb 26, 2007 | 07:38 AM
Default Re: H22a into a 94 Integra LS - Just a few questions - Need clarification (Honda_Fanatic)
Old Feb 26, 2007 | 08:39 AM
H22a1civic's Avatar
Use the 97+ Prelude Power Steering Pump & Bracket. Modify Civic Power Steering Lines to Prelude Pump.
Buy a HCP H22 AC Bracket. It bolts the 92+ Civic SOHC AC Compressor To Bracket (Integra any year or 99-00 Civic Si AC Compressor Will Not Work).
Use a Dayco 5050360 or Goodyear Gatorback 4040410 belt
They will work just fine.
If dont right it should be fine
No, the motor can be dropped in from the the top. You just have to angle it and drop the tranny side in first.
Just the tips
Correct, if your going to use your LS harness
correct
Old Feb 26, 2007 | 10:35 AM
Default Re: H22a into a 94 Integra LS - Just a few questions - Need clarification (H22a1civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">
Should I use an Integra Radiator (planning to get an Aluminum if so) or is it possible to use a EG Civic half sized and still keep AC?
Thanks again
Old Feb 26, 2007 | 02:35 PM
Old Feb 26, 2007 | 07:06 PM
Old Feb 27, 2007 | 10:43 AM
to the top, more info on AC?
Old Feb 28, 2007 | 06:23 AM
JasonST's Avatar
Yeah the half size readiator will work just fine, Many people including me have been using it for years and it works just fine. About the A/C, u need the HCP a/c bracket which relocates the a/c pump. If u want anymore information, I think it was Lak8 who had a great thread on a howto put a/c in an integra/civic with an h22, it was pretty good. Just try searching for it.
Old Feb 28, 2007 | 11:14 AM
Bakeoff's Avatar
#1 Use the prelude PS pump and bracket. You'll need to put your stock PS line. Then get the end of the prelude line (long enough that you can slide a barbed fitting into and clamp it). There is a hard line inside the rubber hose. Just cut it if you need to, but make sure it's not sharp or it will eat away at the rubber housing over time.
You're grafting the two lines together.
#4, mounts? you mean axles?
You want to use the 90-93 integra axles. Then remove the inner joints, rollers, spider gear and boot and throw on the corresponding parts from the prelude axles. You're using the lude inner joints for compatibility, and the teg axles for length.
The spider gear is held in with a snap ring that can be a pain. Just plan ahead and buy some grease to repack the joint, and have a ton of rags handy while working on them. Clamping the middle of the shaft in a vice with it pointing up is the best way to deal with them.
#5 for the harness, before you remove it from your motor, use some masking tape and mark what each sensor is. You'll have to extend the wiring for the alternator. Aside from that, depending on the year motor, obd1 and obd2 use different knock sensor plugs.
Other than that, everything should be pretty straight forward. Make sure you have the extra wiring for the external coil.
Old Mar 5, 2007 | 04:27 PM
1hot4dr's Avatar
Default Re: (Bakeoff)
Hey,hows things going with your swap??
Im doing the same swap...95 DC wit an H22....im pretty much done,still have to get the clutch and shifter **** finished....thats all.
G/L with your swap.....
Subscribed..for a little bit.
Old Mar 10, 2007 | 11:51 AM
captain134's Avatar
Default Re: (1hot4dr)
I've also got a 95 ls with a jdm h22a
I run avid mounts....they do the job but I do have a bit of vibration.
subscribed
Old Mar 10, 2007 | 12:00 PM
JasonST's Avatar
Default Re: (captain134)
I've got an h22a in my 98 teg, if u guys got any questions I'd be glad to answer em. I also got alot of pics of installs, not of everything, but of most things.
Old Mar 11, 2007 | 12:20 PM
captain134's Avatar
Default Re: (JasonST)
yeah I'm interested in some pics! captain134@gmail.com
what mounts did you use?
Old Mar 14, 2007 | 03:34 PM
I just finished my swap yesterday. I will have pics up soon.
Read my Project thread in my sig!
Old Mar 14, 2007 | 08:14 PM
JasonST's Avatar
Default Re: (Honda_Fanatic)
i'm using HCP mounts, I'm not getting much vibration at all. Except when I accelerate in the lower gears at midrange, I'm thinking it's an axle problem. I'm using stage 1 DSS axles. Post up some pics honda_fanatic! It takes me awhile to post up pics cause of really slow upload speed, so if there's anything u guys wanna see in particular let me know and I'll try and post em up or email em.
Old Mar 14, 2007 | 08:50 PM
Old Mar 16, 2007 | 03:01 PM
NJcoupe's Avatar
whats up with your passenger side trans mount?
Old Mar 16, 2007 | 07:03 PM
Default Re: (idriveacoupe.)
what about it? Uses the torque mount location
vteg94
Jun 1, 2007 04:58 PM
Honda_Fanatic
Feb 27, 2007 10:49 AM
SOHC-VTEC-BB2
Feb 17, 2007 03:07 AM
B18 CYA
Oct 24, 2006 12:14 PM
rktegrcr
May 30, 2002 02:09 PM
