Input shaft bearing bad?
Old Feb 25, 2007 | 09:37 PM
CalhounBoi's Avatar
Default Input shaft bearing bad?
I checked the FAQ and saw the thread on this. It seems like the noises I'm hearing are a little different than some others have explained so I wanted to check and make sure.
At idle with the clutch pedal out I hear a loud knocking noise from the tranny. When I press the clutch pedal in the noise goes away. When I engage the clutch in 1st gear there is no noise at first, then at about 5-10mph the knocking comes back getting faster as the engines rpm raises. From there on out the noise is there in every gear until I come to a stop with the clutch pedal pressed in.
Old Feb 25, 2007 | 10:02 PM
4thgenhtch's Avatar
Default Re: Input shaft bearing bad? (CalhounBoi)
Yep sounds like it, I would pull the tranny before anymore damages are done.. It will be pretty obvious which bearings are toast once you split the casing, Dont worry its really not that bad just have a clean, open area to work... Remove the main shaft retaining clip, Split the casing, Pull the reverse idler gear arm off, Then you can remove the entire gear sets from the case and inspect all your bearings.. Iv done it a few times so if ya need anymore pointers let me know
Old Feb 26, 2007 | 04:40 PM
CalhounBoi's Avatar
Default Re: Input shaft bearing bad? (4thgenhtch)
Alrighty. The motor and tranny are already out. I'll check it out tomorrow and see. Is there a secret to seperating the tranny from the block? Do I have to take the starter bolts out or something? We didn't mess with it too much and before I go back out there tomorrow I thought I should check with someone who would know.Thanks for the help, I really do appreciate it.
Old Feb 26, 2007 | 06:23 PM
CivicSD's Avatar
Knocking noise? That is not symptom of an input shaft bearing. I've had one go bad - it just whined louder and louder up until it's demise. Not a single knocking sound.
Can you describe the knocking sound? Like a loose piece or like a bad clutch bearing?
Old Feb 27, 2007 | 02:30 PM
CalhounBoi's Avatar
Default Re: Input shaft bearing bad? (CivicSD)
It's definately a knock, almost sounds like a rod knocking. With the clutch pedal pressed in the noise goes away. Whether I'm idling or going down the road the noise is there as long as the clutch pedal isn't pressed. When I start off in first gear the noise gets louder and faster as the car does. Already bought a clutch release/ throw out bearing and a pilot bearing.
Old Feb 27, 2007 | 02:33 PM
sirtef9's Avatar
http://www.barancoacuraparts.c...l=All
look under mainshaft, and its number 17 I belive. 55$ shipped and a breeze to change
Old Feb 27, 2007 | 02:51 PM
CalhounBoi's Avatar
Default Re: Input shaft bearing bad? (sirtef9)
Would that be a mainshaft bearing? Forgive my ignorance, I can work on a car but I've never torn into a tranny.
Old Feb 27, 2007 | 04:53 PM
sirtef9's Avatar
sorry its number 17 on the mainshaft link. pull your tranny. read your book and find out how to pull off your outter cover, slide the old bearing off and replace..
Old Feb 27, 2007 | 06:01 PM
CalhounBoi's Avatar
Heh, don't have a "book".
Old Feb 27, 2007 | 06:05 PM
sirtef9's Avatar
you have 3 hondas and a bike, buy a book as well lol
Old Feb 28, 2007 | 03:53 AM
CalhounBoi's Avatar
Where can I find a Helms?
Old Feb 28, 2007 | 06:13 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CalhounBoi &raquo;</TD></TR><TR><TD CLASS="quote">Where can I find a Helms?</TD></TR></TABLE>
eBay.
H-T Marketplace.
http://www.helminc.com/helm/pr...54528
Old Feb 28, 2007 | 01:59 PM
CalhounBoi's Avatar
Default Re: Input shaft bearing bad? (Targa250R)
Thank you sir.
Old Feb 28, 2007 | 06:23 PM
CalhounBoi's Avatar
Ok, so since the motor and tranny are out already I want to make one last attempt before I wait on this "book" to get here. Nobody can tell me exactly what needs to be replaced? I'm going to try and pull the tranny off tomorrow and check everything out.
HondaLuv3r4Life
Transmission & Drivetrain
Dec 11, 2013 09:24 AM
theappe
17
Jan 13, 2010 06:09 PM
uNF$@#!
May 13, 2005 07:59 AM
lowbudget88si
Mar 10, 2005 12:31 PM
Ditdogs
Apr 17, 2004 10:57 PM
