ek cluster
Old Feb 25, 2007 | 08:26 PM
honda305's Avatar
Default ek cluster
wuddup the other day i was doing the amber lights on my cluster 96 coupe i changed the bulbs then when i turned them on the whole cluster didnt light up entirley the big bulb didnt turn on neither didnt the small ones on the top....is there anything i gotta check like a fuse or something?
Old Feb 26, 2007 | 05:53 AM
0334973's Avatar
Default Re: ek cluster (honda305)
i did the same thing to my cluster.
the small bulbs are not the exact same size. you have to fiddle around with the connectors a bit to make the contact proper. as for the big bulb, i did not have the problem you are experiencing but i would assume it is the same problem
Old Feb 26, 2007 | 07:36 PM
honda305's Avatar
Default Re: ek cluster (0334973)
the big one is connected to the two little on the top and none of them turn on
Old Feb 27, 2007 | 07:32 AM
honda305's Avatar
bump
Old Feb 27, 2007 | 05:06 PM
0334973's Avatar
check that your big on is properly inserted in the plastic holder and is screwed properly. if there is no contact than it wont light yp
Old Feb 27, 2007 | 05:40 PM
1 sick EK's Avatar
i just bought a si cluster
tofu1413
Jan 28, 2011 08:54 PM
jdmcivicracer89
May 31, 2008 10:23 AM
kcrxxx
Apr 2, 2008 08:13 PM
peter96ek
Feb 15, 2008 01:52 AM
fwdftw
Mar 28, 2004 07:12 PM
