Getting the @#$%&** oil pan off!
Old May 21, 2002 | 09:05 AM
filetofit
Guest
Posts: n/a
Default Getting the @#$%&** oil pan off!
My pan is stuck on there pretty good , how can I get it off without damaging the gasket sealing surface?
Old May 21, 2002 | 09:38 AM
b18b98's Avatar
Default Re: Getting the @#$%&** oil pan off! (filetofit)
how is it stuck? are you sure all oilpan bolts are off? Did you take the flywheel cover off? If yes, put cloth over a flathead and slowly and carefully try to pry it off. Get a new gasket from the dealer or pepboys. Or try to knock it loose by banging it with your fist. Hope you get it off with no problems.
Old May 21, 2002 | 09:42 AM
filetofit
Guest
Posts: n/a
Default Re: Getting the @#$%&** oil pan off! (b18b98)
I'm wondering if I pinch off the valve cover breather and the Crankcase PCV tube and pump pressurized air in the dipstick hole if it'll pop off. or ?
Old May 21, 2002 | 09:59 AM
brcivic411's Avatar
it it's stuck up there, then your gasget was doing it's job... just bang on it ... hopefully the vibrations should help loosen it up, and carefully pry it off with a towel.
Old May 21, 2002 | 10:20 AM
Crazydave's Avatar
Default Re: Getting the @#$%&** oil pan off! (brcivic411)
get a dead blow hammer
MogreSSSJ
Sep 7, 2015 12:57 PM
LightningTeg
Nov 15, 2011 05:12 PM
stupidasso15
24
Oct 5, 2011 12:49 PM
walrus_07
Mar 7, 2009 01:21 PM
BoostedH23Accord
Mar 23, 2007 02:20 AM
