Valve Clearance Question>>>??
I am building a B20 with Aires 12.1 dome pistons and i have a CTR head milled .0030...(skunk 2 valve train) I have a set of buddy club spec 4 cams i wanted to use but i was wondering if i was gonna run into any VAlve ... piston... clearance issiues?? any help.... would help
Yea i know thats what i was gonna do
.... Just wanted to see if anyone has had or built a similar set-up.... I have a few cam options wasnt sure if i wanted to use my buddy club spec 4 or my blox stage 2.... whatever is less of a headace........
I agree that clay sucks for checking valve to piston clearances. I personally use light valve springs to do that job. There is however one clearance check where clay is indispensible, that is checking the radial clearance between the valve head, and the relief pocket. I have seen many instances where either the reliefs were undersized for the valve, or just not located correctly. Keep in mind that removing material from the head or deck not only brings the bottom of the valve closer to the top of the piston, but also brings the edge of the valve closer to the back of the relief.
