Just wondering. Anybody rockin these yet?
damn...those are sick rims....so these wouldnt fit a EG?? the offset would be the negative numbers right???im not all that with wheel numbers thats why....so what offset range would fit hondas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">damn...those are sick rims....so these wouldnt fit a EG?? the offset would be the negative numbers right???im not all that with wheel numbers thats why....so what offset range would fit hondas?</TD></TR></TABLE>
you need something much higher, like a +35 to +42. lower offsets will work, but if you plan on doing anything besides hard parking then its not a good idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrashin »</TD></TR><TR><TD CLASS="quote">
you need something much higher, like a +35 to +42. lower offsets will work, but if you plan on doing anything besides hard parking then its not a good idea</TD></TR></TABLE>
it would cause rubbin while turning right???whats the lowest offset seen on a honda???
it would cause rubbin while turning right???whats the lowest offset seen on a honda???</TD></TR></TABLE>
this one comes to mind..
https://honda-tech.com/zerothread/1899072
so the lower you go on the offset, the more the wheel will stick out right???in the link posted in the first post, theres a -3 offset....would that be a big difference, would it rub???..wheels are 7.5 wide prob would rub while turning right??i really wouldnt
hondayute
Jan 28, 2008 07:23 AM
