SWAP HELP
Old Feb 25, 2007 | 04:24 PM
SCIrONic's Avatar
Default SWAP HELP
Alright so Im going to be swapping a 00' ls b18b into a 00' Em1 shell. I had a couple questions that I couldn't find searching. Will the ls axles work? If not what axles will I need? Will it be a direct plug and play for the ecu? Any other specific parts I will need to make it work? Again I apolagize if this is a repost but I had no luck searching and Im running outa time, thanks
Old Feb 25, 2007 | 04:27 PM
chrischaks's Avatar
Default Re: SWAP HELP (SnowhiteLS)
what motor u had before? d series if so i axles wont work...
Old Feb 25, 2007 | 04:30 PM
SCIrONic's Avatar
Default Re: SWAP HELP (chrischaks)
Its going into a 2000 civic si shell. I own the ls the motor is coming from so I can take whatever parts from that I need so I have the ls axles
Old Feb 25, 2007 | 04:34 PM
chrischaks's Avatar
yep take out everything motor axles computer and im not sure if the cabling will work becouse its diferent from integra to civic u will need a cabling from a dx prolly
ek4_b16a's Avatar
hmm...so you are putting a 00 ls motor into an si? why? if it is an si...bolts right in with the mounts, but i suggest replacing the driver top motor mount with hasport or something...
axels from the si will work...rear mount on si, put it on the ls...and voila...
for the ecu, just get an obd2b>obd1 conversion harness to run an obd1 ls ecu...ehehheheh...
Old Feb 25, 2007 | 04:36 PM
ek4_b16a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrischaks &raquo;</TD></TR><TR><TD CLASS="quote">yep take out everything motor axles computer and im not sure if the cabling will work becouse its diferent from integra to civic u will need a cabling from a dx prolly</TD></TR></TABLE>
ummm....ecu's will work, depends on obd1, obd2a, obd2b...otherwise, the ecus will plug in if it is from the same years...reuse your si harness on the ls...later, do lsvtec...ehhehe...have fun...gl with your swap dawg
rexbooming
Aug 21, 2010 02:49 PM
93LS
Apr 5, 2008 01:19 PM
boosted_ejcivic
Apr 11, 2007 08:01 AM
AGS
Nov 11, 2003 03:45 PM
redhcsi
Mar 31, 2003 04:21 PM
