axle
so i picked up an 1988 crx to swap my b16a outta my 91 4door into. I've got all the wiring harness's un hooked everything is ready to go but the mounts and the axle, I'm a complete noob at engine swaps and was wondering besides removing the axle nut in the middle of the disc brake, is there anything else i must disassemble in order to free the axle out so i can pull the engine and also my axle on my 4door is fucked and the crx came the axle in it can i use that one?
thanks for the info !!!
you will also have to seperate the lower ball joint from the llower control arm. and if the axle that came with you crx is for a crx then no you wont be able to use it. pick you up some 90-93 integra axles for the swap.
PayMecracka
10
Jun 9, 2011 05:43 AM
Modified Motors
Sep 14, 2004 06:16 AM
