what clutch do i use for ls/vtec
Old Feb 25, 2007 | 02:59 PM
skiracer8148's Avatar
Default what clutch do i use for ls/vtec
b18a1 block,im ordering oem clutch so do i order it for 94 integra or?
Old Feb 25, 2007 | 03:01 PM
19992civichatch's Avatar
yes you do.
Old Feb 25, 2007 | 03:06 PM
bmoua's Avatar
why aren't you going at least stage 1? i'd stay away from stage 2 applications though. Going oem isn't a bad idea too...
Old Feb 25, 2007 | 03:08 PM
raphael's Avatar
Default Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">why aren't you going at least stage 1? i'd stay away from stage 2 applications though. Going oem isn't a bad idea too...</TD></TR></TABLE>oem dont spend all that money on a stage clutch unless u have a lsd
Old Feb 25, 2007 | 03:17 PM
yea im gonna go oem.i need it fast do honda dealers have clutches in stock usually or should i just get it from a pep boys or advanced auto store?or should i stick to oem brand exedy?
Old Feb 25, 2007 | 03:21 PM
bmoua's Avatar
Default Re: (skiracer8148)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skiracer8148 &raquo;</TD></TR><TR><TD CLASS="quote">yea im gonna go oem.i need it fast do honda dealers have clutches in stock usually or should i just get it from a pep boys or advanced auto store?or should i stick to oem brand exedy?</TD></TR></TABLE>
no......no.........do not go to autozone,pepboys, and etc....quality wont be there. As for the Exedy OE applications dont get it. I have the exedy oe clutch on my Y8 and pedal feel is way soft bro. I believe there are lot of people here on HT who has the exedy OE clutch and agree with me. It grabs well but the pedal feel sucks. Id either go with the ACT OE clutch (i think they have one), honda oem clutch, or the ACT stage 1 clutch
Old Feb 25, 2007 | 03:28 PM
ok heres another idea,i havnt taken my tranny off yet but my car currently has a act clutch kit from the previous owner so i was told.if the act pressure plate is still good could i use it with the oem clutch disc
Old Feb 25, 2007 | 03:34 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skiracer8148 &raquo;</TD></TR><TR><TD CLASS="quote">ok heres another idea,i havnt taken my tranny off yet but my car currently has a act clutch kit from the previous owner so i was told.if the act pressure plate is still good could i use it with the oem clutch disc</TD></TR></TABLE>
well from what i know you can use a oem pressure plate with a aftermarket clutch disc. All you'll have to do is make sure you resurface the pressure plate. (thats if the pressure plate is still in good condition) As for using a act pressure plate and oem clutch disc i wouldn't know if the combo would be a good idea or not. bump for the answer.
Old Feb 25, 2007 | 03:35 PM
Libertariat's Avatar
Ek Forever y0!
Find gripforce clutches on ebay. Get an oe exedy with a fidanza flywheel.
Might run you $250. Kick-*** setup. Highly recommended and praised in a few threads here on H-T.
Old Feb 26, 2007 | 06:43 AM
one more question,i also have a 98 gsr tranny,the spline is not different right and will work?
Old Feb 26, 2007 | 07:09 AM
92_VX_EG's Avatar
You'll want to get the clutch for a 94-01 Integra, Del Sol Vtec(B16), or 99-00 SI. I wouldn't go with an OEM clutch. As soon as you do a few speed shifts the clutch will be grenaded. They also don't have that much feel. You can run the aftermarket pressure plate with a stock disk. Just clean up the pressure plate with a little sand paper. That holds up pretty good for a while. And don't forget to change your throwout bearing with the clutch if you change it. Me personally I'd go with a street/strip disc or an exedy stage 2(3 puck). They are a little harder to drive until you get use to them but they hold up better if you race every weekend. I'd also suggest a lightened flywheel.
Old Feb 26, 2007 | 08:16 AM
i went with the oem exedy clutch kit for 94-01 integra,that pressure plate in the kit will bolt up to the b18a1 block right?
Old Feb 26, 2007 | 08:38 AM
Ek Forever y0!
yes.
Old Feb 26, 2007 | 10:21 AM
Bfreeman's Avatar
Default Re: what clutch do i use for ls/vtec (skiracer8148)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skiracer8148 &raquo;</TD></TR><TR><TD CLASS="quote">b18a1 block,im ordering oem clutch so do i order it for 94 integra or?</TD></TR></TABLE>
why not go ahead and upgrade.
Old Feb 26, 2007 | 10:25 AM
NACvicSi's Avatar
I don't understand why going through the trouble to go back with OEM? I would do atleast a stage 1. Do you plan on any mods at all?
Old Feb 26, 2007 | 10:30 AM
slodel's Avatar
stage 1 exedy
Old Feb 26, 2007 | 10:48 AM
BEE1's Avatar
stage 1 exedy organic
Old Feb 26, 2007 | 11:07 AM
JDM_COUPE94's Avatar
Default Re: (BEE1)
Go whith a 6 puk act clutch..
Old Feb 26, 2007 | 11:20 AM
Vintech's Avatar
Exedy Stage 1 Organic w/ Exedy Flywheel + B18C1 + LSD =
I really like my setup, i've driven a mildly built GSR with a stage 2 ACT clutch and i liked it also, if i had to pick i would go with either company (stage 1 though)
Old Feb 26, 2007 | 12:35 PM
i do not plan to mod my car besides bolt ons,i am short cash right now.i do not plan on having over 200 WHP,but if i do i can uprgade the clutch
Vague
17
Jan 20, 2016 11:46 AM
jentee
Jun 21, 2008 11:57 PM
tech23
Jun 20, 2008 12:37 PM
DsBananas94LS
Nov 9, 2004 02:51 PM
wongster garage
Oct 7, 2004 07:01 AM
