b16 pulling code 22??
Old Feb 25, 2007 | 01:44 PM
1320king's Avatar
Default b16 pulling code 22??
my pw0 ecu is showing code 22 vtec oil pressure switch...my vtec works, but theres a oil leak from the vtec solenoid i think. anyone think its because of that or somthing els? just asking if anyone had a problem like this, any help would be good thanks!
Old Feb 25, 2007 | 01:56 PM
white90rexsi's Avatar
Default Re: b16 pulling code 22?? (1320king)
Your ecu must be chiped to not look for that sensor. Stock ECU will not engadge v-tec if the oil pressure switch is reading. Have you checked and made sure your oil is full? ( I have seen people with 2quarts of oil and have the light on)? The screen in the solonoid may be cloged as well. When I bought my b16 and installed it I got that code and it was because the screen was cloged. Check your switch. Chances are the oil leak is from your cam seal.
Old Feb 25, 2007 | 11:04 PM
1320king's Avatar
Default Re: b16 pulling code 22?? (white90rexsi)
its a stock "pw0" its not chipped...but ya im gona check the filter and the oil.
Keith_B
Jun 22, 2009 01:14 PM
89civicdx
15
Oct 23, 2008 01:57 PM
denraweb
14
Sep 11, 2007 10:57 PM
SlippylesKB
Nov 12, 2003 07:21 AM
mafioso102
Jun 24, 2002 11:20 AM
