92 clock question?????help!!!!!!!!!
I got sort of the same problem. When I turn my lights or city lights the clock become VERY dim. If i revert back to all lights off it goes back to being bright. Wonder if a bigger Fuse in this situation would help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92EG8 »</TD></TR><TR><TD CLASS="quote">I got sort of the same problem. When I turn my lights or city lights the clock become VERY dim. If i revert back to all lights off it goes back to being bright. Wonder if a bigger Fuse in this situation would help?</TD></TR></TABLE>
You do realize it's supposed to do that, right? It's called a dimmer switch. In USDM Honda's equipped with clocks, the clock goes dimmer when your dash lighting goes on, because it assumes that it's darker outside.
yes i am aware that it dims it assuming its dark out but this is ungodly dark and if i hit the button for it to light up it is how bright its supposed to be. no i have not modified my dash wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-money 92si »</TD></TR><TR><TD CLASS="quote">yes i am aware that it dims it assuming its dark out but this is ungodly dark and if i hit the button for it to light up it is how bright its supposed to be. no i have not modified my dash wiring.</TD></TR></TABLE>
I am aware you have a problem. I was just letting the other guy know that his problem was actually just a factory feature.
Juan Becerril
Classic Hondas
May 27, 2011 01:37 PM
95silverteg
Sep 30, 2008 04:48 AM
wsuozzie
Nov 15, 2006 07:06 AM
