Camshaft ?'s
Old Feb 25, 2007 | 10:19 AM
reaper2022's Avatar
Default Camshaft ?'s
As of now, I have a '94 civic with the D16Z6... this summer I plan on swapping to an H22 and installing Skunk2 stage II camshafts (with an upgraded valve train)... my question is: can you install camshafts/valvetrain without pulling the engine? If you have to pull the engine, I'll buy everything at once and put the cams in before I put the engine in, but I'd rather not spend all that money at once... the H22 swap will be expensive enough...
Old Feb 25, 2007 | 10:56 AM
UncleD's Avatar
Default Re: Camshaft ?'s (reaper2022)
You can install cams and valvetrain without removing the head from the block.
ashb82
May 22, 2008 10:36 PM
bigxclumzy
Sep 9, 2004 04:17 PM
RastaGt1
May 13, 2003 05:46 PM
7rrivera7
Mar 29, 2003 02:19 PM
