d16z6 block, zc pistons z6 head, what comp ratio !
Old Feb 25, 2007 | 04:25 AM
GarageAlchemist
Guest
Posts: n/a
Default d16z6 block, zc pistons z6 head, what comp ratio !
if i use a compresion calc and do d16z6 block, head 0.037 hg, what piston deck height do i use, zc or z6, or somesthing custom.. if i use the z6 ptdh i get 13.6:1, if i use the zc ptdh i get 12:1 comp.. so what ptdh do i use for putting zc pistons in a z6 block/head
Old Feb 25, 2007 | 09:57 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: d16z6 block, zc pistons z6 head, what comp ratio ! (GarageAlchemist)
ttt
Old Feb 25, 2007 | 01:50 PM
GarageAlchemist
Guest
Posts: n/a
here's the problem, 11.971379041131721 is what happens when i get the awesome 1. using the
Deck Height - Compression Height - Rod Length - (Stroke/2) = Piston Deck Clearance
values, (%i6) 212-29-137-90/2; with the sum being 1. and 1 being 1mm = 0.040 in
soo... everyone i've talked to so far said my comp would be 13.2:1.. this math gives me 12:1.. big big diffrence..
help !!! im not ******* half assing this engine build with internet forum say so knowledge
Old Feb 27, 2007 | 02:23 PM
GarageAlchemist
Guest
Posts: n/a
bumps in the night
Old Feb 28, 2007 | 08:12 AM
GarageAlchemist
Guest
Posts: n/a
bump for the knowledges !@@#
Old Feb 28, 2007 | 11:21 AM
DonF's Avatar
What did you cc the head at? What is the piston cc? What is the deck height?
Old Feb 28, 2007 | 12:08 PM
GarageAlchemist
Guest
Posts: n/a
Default Re: d16z6 block, zc pistons z6 head, what comp ratio ! (DonF)
dh is 212, 33.7cc, i dunno the piston cc whatever stock zc is
Old Mar 1, 2007 | 12:30 PM
GarageAlchemist
Guest
Posts: n/a
bumps in the night
Old Mar 1, 2007 | 12:40 PM
spun Vtec's Avatar
use the piston to deck height of whatever piston you are useing. in the calc
Old Mar 1, 2007 | 12:44 PM
spun Vtec's Avatar
Default Re: d16z6 block, zc pistons z6 head, what comp ratio ! (spun Vtec)
use this link http://www.zealautowerks.com/dseries.html
Static Comp Ratio 12.03 : 1
Old Mar 1, 2007 | 02:48 PM
GarageAlchemist
Guest
Posts: n/a
hmm, so with high comp valves should be 12.5:1.. i'm going to clay the crap out of this engine build.. lol
Old Mar 1, 2007 | 04:01 PM
tec_wiz's Avatar
just to let you know, even though you don't need it anymore the piston to deck height of zc pistons on z6 rods, in a z6 is .040. if you are using zc rods then the piston to deck height is .020, because the zc rod is 137.5 mm not 137 like other d16's.
Old Mar 7, 2007 | 09:50 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (tec_wiz)
awesome.. so with my flat faced valves, light decking on block and head, that should bring just a smidge away from 13:1
Old Mar 9, 2007 | 12:45 PM
spun Vtec's Avatar
Default Re: (Eric Theodore Cartman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eric Theodore Cartman &raquo;</TD></TR><TR><TD CLASS="quote">awesome.. so with my flat faced valves, light decking on block and head, that should bring just a smidge away from 13:1 </TD></TR></TABLE> If you plan on running a race gas blend. 12.0-12.5 would be best for a street motor on pump gass. My build will be 12.0:1.
D21X
Feb 16, 2016 08:50 PM
cool_junk
Jan 23, 2008 05:45 PM
GarageAlchemist
Jun 12, 2007 08:28 AM
1.8T_EG
Mar 30, 2003 08:05 PM
BenenEK
Dec 27, 2001 04:31 PM
