Bumper support interchangeable???
Old Feb 25, 2007 | 12:27 AM
ManjuGrip's Avatar
Default Bumper support interchangeable???
I know that the 4th gen jdm bumper support will fit on the usdm bumper but does that mean that the jdm bumper will fit a usdm support? Any information is greatly appreciated! Thanks!
Old Feb 25, 2007 | 12:29 AM
4thgenner's Avatar
Default Re: Bumper support interchangeable??? (ManjuGrip)
i think it should. shouldn't be different.
Old Feb 25, 2007 | 12:42 AM
ManjuGrip's Avatar
Thats what i thougth but you never know. I haven't actually seen it you know so just thought I'd ask to see if there was anyone who was 100% sure.
Old Feb 25, 2007 | 08:33 AM
InvaderTrax's Avatar
Just curious, but does anyone know the weight difference between the JDM and USDM supports?
Old Feb 25, 2007 | 08:38 AM
.BigSexy's Avatar
most hood white kid
Default Re: (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, but does anyone know the weight difference between the JDM and USDM supports?</TD></TR></TABLE>
it is pretty good amount. The JDM support is super light, but the USDM is heavy as hell. Id say its at least 30 lbs. lighter.
Old Feb 25, 2007 | 10:07 AM
spin_r_g's Avatar
Yes you can replace the usdm support with the jdm one no problem. I'm running the jdm right now. You'll save somewhere around 25lbs with the swap. Be careful though cause the jdm one has no strength what so ever. It's not even a support, it's designed to hold the bumper cover up. So don't hit anything or get hit in the front.
Old Feb 25, 2007 | 10:19 AM
kornerk12's Avatar
Default Re: Bumper support interchangeable??? (spin_r_g)
the fourth gen support would not fit a 5th gen correct ??? But is the same true about the jdm one being lighter for the 5th ?
Old Feb 25, 2007 | 10:23 AM
.BigSexy's Avatar
most hood white kid
Default Re: Bumper support interchangeable??? (kornerk12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">the fourth gen support would not fit a 5th gen correct ??? But is the same true about the jdm one being lighter for the 5th ? </TD></TR></TABLE>
Im gonna say yes. I think the JDM ones are lighter because the safety requiresments arent as stiff in Japan as they are in the States
Old Feb 25, 2007 | 10:33 AM
MLBZ521's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spin_r_g &raquo;</TD></TR><TR><TD CLASS="quote">Be careful though cause the jdm one has no strength what so ever. It's not even a support, it's designed to hold the bumper cover up. So don't hit anything or get hit in the front.</TD></TR></TABLE>
lol, How are you going to prevent a wreck to the front?? Going to tell someone that's about to hit your front to not hit that, but try the side, please?
If you're worried about safety say with the OEM USDM Support..
Old Feb 25, 2007 | 11:05 AM
spin_r_g's Avatar
Default Re: Bumper support interchangeable??? (MLBZ521)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">
If you're worried about safety say with the OEM USDM Support..</TD></TR></TABLE>
I mean just to be more careful in gerneal. You know how some people are careless and bump you when parking or things like that. A small bump with the jdm support would do a lot more damge to your bumper cover. I'm not talking like a huge wreck cause even with a usdm support you'll be screwed.
Old Feb 25, 2007 | 02:15 PM
SteveoBA8's Avatar
I have a 4th gen jdm bumper support laying in my basement. It is pewny compared to the usdm.
Old Feb 25, 2007 | 02:34 PM
kornerk12's Avatar
Default Re: Bumper support interchangeable??? (SteveoBA8)
What about the rear, is a jdm rear support also compatable and lighter than a usdm one ?
Id like to know for sure if they both fit before i go and order them. Is anyone positive ?
C_R_X_
May 3, 2009 10:28 AM
JDM.Type-r
Jan 16, 2008 04:50 AM
Circuit Star-29
Apr 24, 2007 08:32 AM
J.nguyen
Nov 27, 2005 12:48 AM
da9pwnsu
Nov 1, 2005 03:49 PM
