phearable.net 2 step launch
Ok got all my part in they consite of
Gsr block, ls crank, ge oil blocks, blox type a's, blox duel valve springs,crower chromoly retainers, srp 81.5 supposed to be 10.5-1 in a b17 but dome is a mm taller then pr3's, shot peened magna fluxed and polished ls rods fitted with arp rod bolts, also gsr head with fresh 3angle vj, edelbrock pro flow 1 peice with collector mod and h22 345cc
i converted to obd1 and asked for a 2 step launch from phearable recieved the ecu, tried in my friends lsvtec dc and no launch limiter
called them and they told me they were affraid it would mess something up since my ef is converted cuz my vss isnt electronic. But to my knowledge there is in fact a speed sensor in the cluster Code 17=vss right ? anyone else have this problem ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ef9 »</TD></TR><TR><TD CLASS="quote">Ok got all my part in they consite of
If your ecu was not seeing vehicle speed the vehicle would throw a code 17.
If you would like us to install a 2 step on your ecu that works off the speed sensor at 0 mph we can do so. Simply contact us to mail back the ecu for re-programming.
Thank You,
John Vega - Phearable.net
</TD></TR></TABLE>If your ecu was not seeing vehicle speed the vehicle would throw a code 17.
Thank You,
hey i wasnt talkin smack on your company at all, sorry to make it sound like that i called you and told me it might screw my car up i just wanted to confirm it was ran off of speed sensor Thank you for a good product sir
phearable.net has great service and its worth the price i got one for my b20 sol and it works great.. i fully recomend getting one of there chipped ecu's there programed for your car...
your Vss working or not?
</TD></TR></TABLE>your Vss working or not?
psegs80
Feb 9, 2009 11:15 AM
blu3g
38
Jul 30, 2005 08:15 PM
. i know where ill be purchasing my ECU
