Which velocity stack is better?
Old Feb 24, 2007 | 10:33 PM
4dooritr's Avatar
Default Which velocity stack is better?
What are you thought's on Prototype Racing stack vs BPi stack?
I plan on using one of these with a AEM Dryflow filter.
don't know which one to choose... any dyno's between the two?
Old Feb 25, 2007 | 05:11 AM
Jdmb16sir2's Avatar
Default Re: Which velocity stack is better? (4dooritr)
i perfer the bpi strong lightwight great design check out the dyno results on his home page
http://www.bpinitiatives.com
Old Feb 25, 2007 | 08:03 AM
flesh199's Avatar
Default Re: Which velocity stack is better? (Jdmb16sir2)
bpi hand down
Old Feb 27, 2007 | 05:00 AM
salman's Avatar
i have design one my self.
want to see any pics?
Old Mar 13, 2007 | 08:02 AM
p0gi_b0i_integra's Avatar
has anyone tried a velocity stack in conjunction with the comptech icebox?
Old Mar 13, 2007 | 08:45 AM
flesh199's Avatar
Default Re: Which velocity stack is better? (p0gi_b0i_integra)
look for my answer in the other thread
Old Mar 13, 2007 | 05:43 PM
dfoxengr's Avatar
Default Re: Which velocity stack is better? (flesh199)
mathematically your lowest entrance loss coefficient will occur when the radius of curvature of the inlet divided by the inside diameter is greater than 0.25
r/D <= 0.25
3" ID---> needs a 0.75" radiused entry
after that it will still help, but not too much.
this helps the fluid to not separate from the surface when travelling along it.
Old Mar 13, 2007 | 06:42 PM
Brick Top's Avatar
Default Re: Which velocity stack is better? (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">
this helps the fluid to not separate from the surface when travelling along it.</TD></TR></TABLE>
you mean air? right?
Old Mar 14, 2007 | 04:06 AM
dfoxengr's Avatar
Default Re: Which velocity stack is better? (brick top)
yes air is a fluid
Old Mar 16, 2007 | 11:31 AM
litovi3tboi503's Avatar
do they make anything for the ported s housing?
Old Mar 16, 2007 | 11:52 AM
onepoint6i's Avatar
Default Re: Which velocity stack is better? (litovi3tboi503)
circuit hero just came out with a new air horn for those of you interested, it makes proven dyno HP. this same design netted about 10HP in conjunction with a 3inch short ram on our circuit hero Type R some time back..
http://www.circuithero.com/products.html
Dirt
Jul 28, 2002 09:48 PM
95BlackGS-R
Jun 27, 2002 01:32 PM
juniordc2
Mar 28, 2002 06:04 PM
blktyper2001
Sep 4, 2001 04:07 PM
AllMotorITR
Jun 27, 2001 07:35 AM
