99 Accord Clock
Old Feb 24, 2007 | 09:34 PM
VeEzyV's Avatar
Default 99 Accord Clock
i just got my accord and after driving it at night i noticed that tha clock light does not work. is it an easy fix? is there a diy to how to fix it? thanks in advance
Old Feb 24, 2007 | 09:39 PM
SuShiBoiiii's Avatar
Default Re: 99 Accord Clock (VeEzyV)
yeah get a new bulb and replace it
Old Feb 24, 2007 | 09:45 PM
VeEzyV's Avatar
how do i replace it? and what kind of bulb?
Modified by VeEzyV at 11:00 PM 2/24/2007
Old Feb 24, 2007 | 09:48 PM
Default Re: (VeEzyV)
go to the dealership and get one about 2 bucks or less and then use both of your hands and pull it
Old Feb 24, 2007 | 09:59 PM
VeEzyV's Avatar
wth. its that easy? thanks dude
Old Feb 24, 2007 | 10:47 PM
yup its that easy
Old Feb 25, 2007 | 01:47 AM
Defcon1's Avatar
flathead screwdriver under the bottom of the clock does the trick to get the clock out...
Old Feb 25, 2007 | 02:28 AM
Default Re: 99 Accord Clock (Defcon1)
that works too
Old Feb 25, 2007 | 02:30 AM
nowind's Avatar
yeah its easy... but here on Guam they charge
about $4.25 for that little bulb. B.S. if you ask
me. I talked the guy into giving me a discount
but 10% off doesn't do much.
Old Feb 25, 2007 | 08:49 PM
Heat's Avatar
Default Re: (nowind)
Take a look at step 24 of these instructions, it'll explain & give a diagram on how to pop the clock / hazard light out.
http://www.handa-accessories.c...k.pdf
Old Feb 25, 2007 | 10:09 PM
VeEzyV's Avatar
thanks for all tha help guys. i jes ordered the light and i'll have it fixed asap. i'll also present to you guys my accord. its a purple 99 v6 ex coupe w 7th gen wheels and tint.
Old Feb 26, 2007 | 08:02 AM
Tyte-S's Avatar
Is it s'pose to light up? I have an '00 Accord and mines never lit up.
Old Feb 26, 2007 | 08:14 AM
Heat's Avatar
Default Re: 99 Accord Clock (f23a4t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f23a4t &raquo;</TD></TR><TR><TD CLASS="quote">Is it s'pose to light up? I have an '00 Accord and mines never lit up.</TD></TR></TABLE>
Yes, though I think it's only when your headlights are on. If you can't read the clock at night, your bulb is burnt out.
Mine has never burnt out but my cruise control button did - but I actually like not having the cruise control light so I never fixed it. (the light on the cruise control button on the lower left dash).
Old Feb 26, 2007 | 08:57 AM
02 accord's Avatar
It is supposed to light up every time the ignition is on.
Old Feb 26, 2007 | 02:16 PM
361 accord's Avatar
hahaha yeah i just "stole" the bulb out of the hazard button, its the same bulb, just pull straight out with ur hands...
nuff said, go to the accord faq and its in the TSB's that and osme other cool stuff thats recalls or w/e
Old Feb 26, 2007 | 05:04 PM
nowind's Avatar
mine is on whenever the ignition is on.
Old Mar 2, 2007 | 07:12 PM
VeEzyV's Avatar
ok i got a problem. i changed the clock bulb but it still doesnt light up. also i didnt realize it until i changed it that the bulb below it is burnt out as well.. or at least i think so (the climate control one or w/e its called). does it use the same bulb as the clock? do u guys think its the bulbs that are burnt out or maybe a shortage?
russlan44
Jul 6, 2007 11:14 AM
shortlid
Mar 30, 2007 11:08 AM
PVD24
Jul 3, 2006 09:01 AM
ondenoantra
Apr 28, 2004 06:55 PM
