Weighed My Car This Weekend...
Old May 21, 2002 | 07:00 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Weighed My Car This Weekend...
Went to a county water authority plant and used their scale to weigh my car.
Although I question the scale's accuracy because of it's size and the fact that it read 200lbs. BEFORE we put a car on it, I guess it gives me an idea of my car's weight.
2040lbs. with 1/2 tank. 5 gallons of gas = 40lbs. or so, so my weight is:
2000lbs. even.
My pal that works there does say that the scale isn't perfect though, because it measures big-*** trucks that weigh 32,000lbs. or so, so it isn't really calibrated to measure tiny crap like cars like mine.
I'll se for sure this weekend at the strip.
My set-up could be lighter if I had a header rather than the cast-iron stock manifold, non-Airbag steering wheel, and a C/F hood.
The header alone would net me sub-2000lbs.
I'll list the complete set-up later when I have more time, but real quick:
1992 CX stripped (details later)
B18C5 swap
4-wheel disc brakes
Later y0!
Old May 21, 2002 | 07:07 AM
slowEJ6's Avatar
Default Re: Weighed My Car This Weekend... (B18C5-EH2)
cool
my cars fat.
Old May 21, 2002 | 07:08 AM
DevinW's Avatar
Damn that's pretty good man! And you car still has a little bit of weight to lose..
Old May 21, 2002 | 07:55 AM
DR. ON POINT's Avatar
Banned
Default Re: Weighed My Car This Weekend... (C5_ALLMOTOR)
good job Tom
Old May 21, 2002 | 08:44 AM
EVIL Hx Coupe's Avatar
Default Re: Weighed My Car This Weekend... (On Point EK!!!!!!!!)
thats light ....
Old May 21, 2002 | 09:03 AM
93LSivic's Avatar
Thats pretty light! GOod job on the car. You are the most **** person on ht about the civic hatch weight, so keep up the good work.
By the way, I weighed my Si this weekend. 2505, with me in it, full interior, 1/4 tank of gas.
Its cool, just turn up the boost a little bit if anyone wants to whine about how heavy it is.
Old May 21, 2002 | 10:41 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yeah those big scales meant for trucks aren't anywhere near accurate enough to measure the miniscule weight of a car. The truck guys aren't looking for alot of accuracy, they just have to make sure they are under the weight limit for whatever state they are driving through. Take your car to a track or try to get on a set of corner scales to get an accurate measurment.
[Modified by PatrickGSR94, 1:41 PM 5/21/2002]
Old May 21, 2002 | 01:56 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Okay so what's removed to help get sub-2000lbs. on a 1992 CX?
Removed the following:
Tar (not much - used dry ice method)
Carpet
Headliner
Door plastics and plastic sheets with goo
Rear plastic panels including hatch plastic
Knee bolster bar
No rear seats or seatbelts
No spare (that's a given)
Firewall mat on the inside of the car
NO radio or speakers - VTEC is just fine
All SRS ECU and harnesses
No wipers or wiper motor - Rain-X works like a charm
Car already had no A/C at all, no power steering, etc.
Lighter wheels - Rota 15x6.5 @ 12lbs. a piece
Tanabe Super Medallion Racing Spec - 1/2 the stock exahust weight
What's still there that some people remove?
Both bumper suports
Side impact beams
Driver side airbag (will remove)
Heater Core (got to have heat y0!)
What's there that ADDS weight?
B18C5 motor swap
Rear disc conversion
My plans to furher lighten the car include the previously mentioned addition of a header (should save at least 15lbs.) and later down the road a C/F hood.
Old May 21, 2002 | 02:21 PM
RATEDR's Avatar
CF hood OWNZ!
Old May 21, 2002 | 06:25 PM
vntperformance's Avatar
well
my car weighed in at 2140 w/o me in it! with less then 1/4 tank gas, JL Audio speaker box..my damn (2) tool boxes...and full interior..and more junk in the trunk, so i think now that it's gutted..it probably weighs somewhere in 1900lbs (Hypothectically Speaking)
Old May 22, 2002 | 04:50 AM
Mista Bone's Avatar
D Tranny Guru
your car might be under 2000 already with listed 'lightening".
Old May 22, 2002 | 05:33 AM
Rezon's Avatar
Default Re: Weighed My Car This Weekend... (Mista Bone)
did you ever consider lexan windows in the back?
Old May 22, 2002 | 05:39 AM
Community Builder
Default Re: Weighed My Car This Weekend... (Rezon)
Lexan isn't street legal, plus it scratches like hell if anything touches it.
Old May 22, 2002 | 07:27 AM
SpiceyRice's Avatar
Carpet
Headliner
Knee bolster bar
B18C5 motor swap
Your car is really light!
I have a 92 CX EG, fully stripped -- everything is gone per your list above except for the windsheild wipers (if one adds 5hp, 2 add 10hp, right , full ITR drivetrain, and ITR suspension/brakes -- and a 8 point cage and it weighs 2250lb. I think it had near a full tank of gas when weighted, so 2200lb is a pretty good dry estimate. I think the cage adds ~100-150lb -- so I guess we're in the same ballpark.
btw, weighed on very accurate corner weights.
[Modified by SpiceyRice, 11:28 AM 5/22/2002]
Old May 22, 2002 | 07:29 AM
SpiceyRice's Avatar
Default Re: Weighed My Car This Weekend... (SpiceyRice)
This must be for drag racing, because I've gotta believe you're already below the minimum weight for an EG in most IT spec classes.
Old May 22, 2002 | 07:35 AM
ZXVIIR's Avatar
cf hood ownz you....LOL
on the car over all once again,
and you know what **** the c/f hood!
keep it as light as possible without all the
typical cf pieces, leave the car as O.E. looking
as possible IMO. i love the ride the way it is...
Old May 22, 2002 | 08:06 AM
Pat McGroin's Avatar
Default Re: Weighed My Car This Weekend... (Snatchback)
mm mmm mm , how do you do it?
Old May 22, 2002 | 08:11 AM
HOND PWR's Avatar
My car is a pig...93 CX with GSR swap=2500lbs
Old May 22, 2002 | 09:22 AM
dphi's Avatar
Default Re: Weighed My Car This Weekend... (HOND PWR)
Are you sure that's an accurate measurement? My EX w/ GSR swap weighed in at 2510 with a speaker box, stock exhaust manifold, integra leather seats, etc. 2500 for a CX sounds way too heavy.
Old May 22, 2002 | 09:47 AM
fastfour's Avatar
That is heavy as hell. My 94 EX w/ LS and JRSC is only 2378. You sure that's accurate?
Old May 22, 2002 | 10:59 AM
KoRn_vIRuZ's Avatar
Wouldn't this make your car ~1800 lbs? That would be unbelievable!
Old May 22, 2002 | 11:11 AM
HOND PWR's Avatar
Default Re: Weighed My Car This Weekend... (KoRn_vIRuZ)
I used the scales where I work they are pretty acurate. My car has everything GSR swap,GSR suspension ,ac ,stereo ,pwr windows+locks even a spare tire and jack.
Old May 22, 2002 | 11:19 AM
Community Builder
Does it have the GS-R power steering and PS rack?
Old May 22, 2002 | 11:44 AM
Trey's Avatar
25 Year Member
Default Re: Weighed My Car This Weekend... (PatrickGSR94)
Get a CF hood and paint it VSM if you don't like the "look"of the weave.
The weight advantage of the CF hood is worth it.
Personally, the black hood would finish off the car and a duckbill.
Again, you could paint both to make it more of a sleeper.
Old May 22, 2002 | 11:50 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Weighed My Car This Weekend... (Trey)
The scale read 2240lbs., so minus the 200lbs. and the 40 for gas and you have 2000lbs. even.
