14.2@96mph stock B18c Hatch,,, want low 13s high 12s
Old Feb 24, 2007 | 07:47 PM
locote's Avatar
Default 14.2@96mph stock B18c Hatch,,, want low 13s high 12s
Ive done this time with stock B18c..
2.5inch exhaust
SRI
PowerFC (stock map)
What combo could get me into low 13s high 12s
current compresion is 10.6:1
Id like my compresion to remain same as motor is pretty fresh( 225psi on all 4)
Im thinking of starting with a TODA header and Skunk2Pro manifold..
what else would get me my target times
Old Feb 24, 2007 | 07:59 PM
tagperformance's Avatar
Default Re: 14.2@96mph stock B18c Hatch,,, want low 13s high 12s (locote)
High lift cams, valvetrain and head work! That should give you a nice jump in power.
Old Feb 25, 2007 | 01:09 AM
locote's Avatar
Default Re: 14.2@96mph stock B18c Hatch,,, want low 13s high 12s (tagperformance)
Skunk2 Pro stage 1s with 10.6:1 comp with pro manifold should be a good combo or u think i can run and make good use of stage 2 Pros???
Old Feb 25, 2007 | 02:36 AM
Winlight's Avatar
nice time,good job
Old Feb 25, 2007 | 06:29 AM
1 2 NV's Avatar
slicks, best bang for the buck period.
Old Feb 25, 2007 | 07:21 AM
DaveF's Avatar
Default Re: 14.2@96mph stock B18c Hatch,,, want low 13s high 12s (1 2 NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">slicks, best bang for the buck period.</TD></TR></TABLE>
slicks/ 75shot, that will do it for sure
Old Feb 25, 2007 | 02:32 PM
jdmegmong's Avatar
Default Re: 14.2@96mph stock B18c Hatch,,, want low 13s high 12s (dturbocivic)
b18c1, p30 pistons, type r camshafts, blox IM, greddy 4-2-1, portflow valvetrain, gsr tranny, itr flywheel with exedy stage 1 clutch, 20x6x14 MT's
13.4@100mph with 1.8 60's in a 92 hatch(2105lbs without driver)
Old Feb 25, 2007 | 03:46 PM
Richard...'s Avatar
Default Re: 14.2@96mph stock B18c Hatch,,, want low 13s high 12s (jdmegmong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmegmong &raquo;</TD></TR><TR><TD CLASS="quote">b18c1, p30 pistons, type r camshafts, blox IM, greddy 4-2-1, portflow valvetrain, gsr tranny, itr flywheel with exedy stage 1 clutch, 20x6x14 MT's
well he could put his car on a diet always helps! and of cause slicks!
Old Feb 25, 2007 | 05:56 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
slicks/ 75shot, that will do it for sure </TD></TR></TABLE>
that will do it, and for close to the price of some aftermarket cams or other bolt on.
Old Feb 25, 2007 | 10:10 PM
EdmondsWashington's Avatar
If your looking for mods that may not be used all the time but for short term use.
Old Feb 25, 2007 | 11:35 PM
Calvinator's Avatar
or at least some drag radials, and you will see that 13 second slip
Old Feb 26, 2007 | 04:58 PM
. a d a m's Avatar
slicks and some more seat time will get you mid-13's.
Old Feb 26, 2007 | 05:04 PM
Honda Bull's Avatar
This is very similar to mine.
B18C1, short ram intake, 2.3" exhaust, 6-puck clutch, and 20x6x14 MT's put me at 13.40 @ 101 mph. Weighing 2275 with driver.
So to the OP, slicks, cams, nice header, B16 tranny, good tune would probably net you the high 12 you're looking for. But I'm sure it can be done without the B16 tranny and header.
Old Feb 26, 2007 | 10:35 PM
locote's Avatar
Default Re: 14.2@96mph stock B18c Hatch,,, want low 13s high 12s (Honda Bull)
I got a JDM B16a tranny already and Just baught a BuddyClub header...
ill also fit a Skunk2 mani later with stage 2 pro cams
But im racing tomoz i wanna shoot a high 13..
Tomorows setup is..
same as before but mandrill bent 2.5inch exhaust, and my FPR got adjusted as it was running lean last run..
and also using semislick TOYOs R888s..
ill be happy with 13.9..
Old Feb 27, 2007 | 01:16 AM
Dyno Dave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locote &raquo;</TD></TR><TR><TD CLASS="quote">Ive done this time with stock B18c..
2.5inch exhaust
SRI
PowerFC (stock map)
what else would get me my target times</TD></TR></TABLE>
You know the drill we have a few here on this side of Australia running mid 13's with STD engines,headers,intakes,my tunes you will just have to wait till we get over there in March
Regards Dyno Dave
Old Feb 27, 2007 | 06:59 AM
zap's Avatar
zap
13.78@101mph
2.2 60ft
170whp B16a(stock stroke stock bore)
195/55/r15 advan a032rs
Full-interior EF hatchback
locote: Weight reduction will help you get that 13sec timeslip. What was your 60ft?
Old Feb 27, 2007 | 07:26 AM
integra_gsr98's Avatar
Default Re: (zap)
We took a pair of beaters out a few summers ago:
91 Integra RS, gutted, stock motor, stock header, 65 shot, 24.5" slicks, 13.0 @ 102
92 Civic Hatch DX, somewhat gutted, LS Swap (all stock), ebay header, cheapo exedy clutch, 50 shot, 20" slicks, 13.2 @ 101
We never did get to run 75 shots on both cars, would have been 12 second cars for under $2500 each.
Old Mar 1, 2007 | 03:21 AM
locote's Avatar
2.345 60ft..
Old Mar 1, 2007 | 04:33 AM
ATYPR's Avatar
Default Re: (integra_gsr98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra_gsr98 &raquo;</TD></TR><TR><TD CLASS="quote">We took a pair of beaters out a few summers ago:
We never did get to run 75 shots on both cars, would have been 12 second cars for under $2500 each.</TD></TR></TABLE>
Old Mar 3, 2007 | 06:03 AM
NABeastRR's Avatar
Default Re: (FUCATYPR)
i had blox intakemani 64mm t/b itr header itr 4.7 tranny act clutch n 12 pound flywheel ctr crank pulley 13.0 on drag radials & 12.8 wit 23 inch slicks 1.6 60fts that was it no cams or nothin like that oh & a skunk2 ebay chip never got really tuned wit a b18c
Old Mar 3, 2007 | 04:44 PM
vtec25's Avatar
Default Re: (NABeastRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NABeastRR &raquo;</TD></TR><TR><TD CLASS="quote">i had blox intakemani 64mm t/b itr header itr 4.7 tranny act clutch n 12 pound flywheel ctr crank pulley 13.0 on drag radials & 12.8 wit 23 inch slicks 1.6 60fts that was it no cams or nothin like that oh & a skunk2 ebay chip never got really tuned wit a b18c</TD></TR></TABLE>
How much did ur car weigh?
Old Mar 3, 2007 | 04:58 PM
NABeastRR's Avatar
Default Re: (vtec25)
deff less then 2300 lol .....it was 2050 wit me in it last season gutted some more only like 50 pounds but still gotta re wiegh it but ill have alot more done this season goal 210 to 220 whp & 12.20s or better on the slicks hopefully
EG6 Love
Apr 19, 2007 08:57 AM
motohatch557
16
Aug 17, 2004 08:43 PM
tour de france turbo
Oct 16, 2003 11:14 PM
quikyEG
Apr 24, 2003 07:25 AM
FastJustin
Sep 7, 2002 07:15 PM
