kyb agx w/ ground control sleeves, cusco swaybar and prothane brackets
all prices are best offer, be reasonable and so will i. as always i ship through fedex and you'll get a tracking number once your item ships. i have many happy customers.
kyb agx shocks with ground control sleeves and adjusting nuts for 96-00 civics. shocks used for 1.5 summers. still work like new. my car was never slammed on these, they're only recommended to be dropped 1.5in which i wasn't even that low. only problems are on one of the rear shocks the tab you use to tighten is broken off(shown in pic). this does not effect performance. i had to hold the piston rod to get the nut off so there are marks where the wrench was on it(shown in pic). these scratches are not deep and won't effect performance either unless you slam your car. all the gray marks are anti seize not scratches.
ground control sleeves used for 3 summers. adjusting nuts are scratched up but totally functional. comes with all the o-rings and instruction book. all you need are some 2.5in springs to mount these up to your car.
will separate shocks from sleeves if price is right
SOLD to: silentrg03
cusco 18mm swaybar with prothane poly d-brackets for 96-00 civic. powdercoated satin black, i didn't like the blue. 3 hole stiffness adjustments. BRAND NEW only mounted on car, was never driven on. i decided to get something bigger. paid $140 for the sway and $30 for the brackets.
MOVED
edit: sale over
edit: item sold
edit: price lowered on shocks
edit: prices lowered
Modified by Heretic:Si at 8:41 AM 2/25/2007
Modified by Heretic:Si at 11:10 AM 2/27/2007
Modified by Heretic:Si at 4:41 PM 2/28/2007
Modified by Heretic:Si at 12:23 PM 3/2/2007
SOLD to: silentrg03
MOVED
edit: sale over
edit: item sold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman »</TD></TR><TR><TD CLASS="quote">Good prices.
thanks
</TD></TR></TABLE>thanks
Is an 18mm that sway bar that much different than a 22mm type r bar? It seems like a nice intermediate stage between the 13mm si and the 22mm type r.
bump for good deals
bump for good deals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Budget EJ »</TD></TR><TR><TD CLASS="quote">Is an 18mm that sway bar that much different than a 22mm type r bar? It seems like a nice intermediate stage between the 13mm si and the 22mm type r.
bump for good deals
thanks for the bump. i really couldn't say how much difference there would be since i didn't drive on it, i think it would be close. when i bought it i thought it would be a nice compromise between 13mm and 22mm, plus it's adjustable.
pm's replied
bump for good deals
</TD></TR></TABLE>thanks for the bump. i really couldn't say how much difference there would be since i didn't drive on it, i think it would be close. when i bought it i thought it would be a nice compromise between 13mm and 22mm, plus it's adjustable.
pm's replied
BoosterSH
Oct 13, 2003 09:34 AM
