a lil help
Old Feb 24, 2007 | 01:56 PM
91SI92's Avatar
Default a lil help
hey whats up guys. i recently did a jdm swap. went from a h23 to a jdm h22. i put the h23 dizzy on the h22 because i'm running all msd with an external coil and i also swapped out the ecu. the ecu is jdm h22 as well. the problem i am havin is with the vacuum lines and the rev limiter. its still redlining at 6500 n i thought the h22 redlined at 7500. so does the computer control the rev limiter or do the dizzy? please help. thanks
Old Feb 24, 2007 | 02:13 PM
darkspector2.0's Avatar
you do have a p13 right?
Old Feb 24, 2007 | 02:44 PM
petern101's Avatar
Default Re: (darkspector2.0)
the ecu controls it.
made sure you hooked everything up correctly? (mainly wiring up vtec correctly) because vacuum lines won't give that type of problem
Old Feb 25, 2007 | 02:29 PM
91SI92's Avatar
Default Re: (petern101)
yeah erything is hooked up right. i don't have the vtec solenoid and oil pressure switch hooked up yet. n yeah its a p-13 ecu. i have yet to do the vacuum lines.... thats gonna be real fun.
Old Feb 25, 2007 | 02:38 PM
SteveoBA8's Avatar
Default Re: (91SI92)
Look in the Prelude faq's, there is a vacuum diagram.
Old Feb 25, 2007 | 03:05 PM
SikB's Avatar
Default Re: (SteveoBA8)
I think you have to get VTEC working to get higher redline. Even if you didn't you wouldn't or at least shouldn't want to rev your engine that high without it.
Old Feb 25, 2007 | 05:19 PM
petern101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SI92 &raquo;</TD></TR><TR><TD CLASS="quote"> i don't have the vtec solenoid and oil pressure switch hooked up yet. </TD></TR></TABLE>
and you are wondering why it doesn't rev past 6500? seriously?
its like asking "why doesn't my car move? i have tires sitting on the driveway but they aren't on the rims yet"
you need everything to work in order to not throw a code for vtec to achieve a 7600 rpm limit
Old Feb 26, 2007 | 03:17 PM
91SI92's Avatar
Default Re: (SikB)
thanks for the info. i'm new wit the vtec motors. i usually ran an H23 that murdered all H22's so thanks for the info. that other guy who had the smart replycan kiss the sky.
Old Feb 26, 2007 | 09:28 PM
snobordboy's Avatar
Moderator
Yeah it wont run up that high without all the vtec wired and such, and I would say unless you have vacuum right, or at least all plugged and run so it runs with no leaks, dont even driveit, and really dont try to rev it up that high.
serjey15
May 5, 2010 03:51 AM
crx2fast
Aug 10, 2004 10:07 AM
jdmitr
Sep 9, 2003 09:41 PM
jdmitr
Aug 21, 2003 10:27 PM
chidoks
Jun 15, 2003 07:34 AM
