Posting pics...
I know this forum will probrably be deleted soon cuz it doesn't have to do directly with civics, but I need help uploading pictures onto this site. I've tried a few times to post a pic in the FG squad forum but I can't get it done. All of the photo's are saved in a folder on my desktop - any advice? Thnx -
if u look in the top of a reply to a post there are a bunch of icons
CLICK THE QUESTION MARK
[b]
Text Edit Toolbar Help
The Text Edit Toolbar appears above most text entry boxes in the ZeroForum software.
This toolbar allows you to insert text formatting directly into your current document.
The B option allows you to add bold formatting to your text.
The I option allows you to italicize text.
The U option allows you to underline text.
The Web Link option allows you to insert HTML Links into your document.
The Image option allows you to insert linked images into your document.
The Preview option allows you to preview the document in real time. The preview option renders all text formatting and HTML references to a pop up preview window.
If the Spell Check option is enabled on this site, you may click the Spell Check button to check your document for spelling mistakes. You will be presented with a list of suggested words for each misspelling found. Changes will be made to your document in real time.
In supported browsers, text formatting can be done on selected text. For example, to bold a word, first highlight the word and then click the B option. Bold formatting will be inserted around the selected word. If this does not function as described, you may not be using a supported browser. In these browsers, text formatting will be inserted at the current cursor position rather than applied to the selected document text.
Image Posting Help
Using the Image option to insert linked images directly into your document. These images must be on a web server on the Internet. Images linked from your local computer will not function correctly.
To insert an image, provide the Internet URL to the desired image, select the URL with your cursor, and then click the Image option on the text formatting toolbar. For example, if the desired image's URL is http://www.yourserver.com/picture.jpg, you would provide this URL and then click the Image button to insert the appropriate [IMG] tags around the image URL.
If file attachments are enabled on this ZeroForum site, you may also be able to attach an image file directly from your computer to this post. Via this route, images do not have to be hosted on an Internet web server to be displayed.
Powered by ZeroForum 2.1.2b. ©2005 RelyNet, Inc.[/b/
[b]
Image Posting Help
