overheating Ls
Old Feb 23, 2007 | 09:25 PM
grog's Avatar
Default overheating Ls
I bought an 89 hatch with a ls motor with 150k++. the previos owner changed the water pump 10,000 miles ago, it had overheating problems even after that. it gets up to 240 degrees and the fan wont kick in, so i hardwired it. that doesent help. the head gasket isnt blown, ive changed the radiator(aparently he had too ) new thermostat the radiator cap is good, i dont think theres any air in the system. theres no flow trough the lower radiator hose, and I know I installed the themostat correct. also the temp gauge seemed to be rising and falling to fast to be right so i put a auto meter gauge in, it seems correct now. i dont know what that has to do with anything. its burning oil for sure. its kinda a part car right now, i would like to beat on it though.
so im left to believe the water pump is bad or not installed correct . I think thats the only part of the coolant sytem left to replace.
any help would be apreciated
Old Feb 23, 2007 | 11:54 PM
Redline130's Avatar
Default Re: overheating Ls (grog)
If there is no flow through the bottom hose, then the thermostat must be stuck shut. Are you sure that you have all of the air out of the system? Try running the car without the thermostat and see what happens then.
Old Feb 24, 2007 | 06:49 AM
Crx Jimmy's Avatar
the thermo could be bad even if its new, put it in a pot of water that has a thermometer in it and see if it opens up at the proper temp when you heat it. other than that was the pump installed a honda one, it could have been a cheap parts store one which I have seen have problems
Old Feb 24, 2007 | 09:46 AM
grog's Avatar
Default Re: overheating Ls (Crx Jimmy)
thanks. ill try removing the thermostat
88HATCH(:
17
Mar 27, 2012 07:04 AM
new_climber
Dec 14, 2008 10:07 PM
nels415
Sep 21, 2005 12:27 PM
trashkilla
Oct 15, 2004 11:16 AM
quickLSt
Nov 21, 2001 12:21 PM
