b16a helms manual for 88 crx si
Old Feb 23, 2007 | 08:05 PM
msinsky14's Avatar
Default b16a helms manual for 88 crx si
I found a 1994 del sol helms manual but it doesnt say if it covers the b16 vtec version. im assuming they all do but just want to make sure. same with the crx ones, it covers si model as well am I right?
thanks
Old Feb 23, 2007 | 08:55 PM
msinsky14's Avatar
Default Re: b16a helms manual for 88 crx si (msinsky14)
bump
Old Feb 24, 2007 | 12:12 AM
JustJesus's Avatar
just picked up a repring for a 1990 crx, and yes, it covers the Si model. I'm assuming the Del Sol one should cover the VTEC version as well.
Did you get OG manual?
Old Feb 24, 2007 | 06:22 AM
msinsky14's Avatar
Default Re: b16a helms manual for 88 crx si (JustJesus)
wat u mean by "OG manual?"
Old Feb 24, 2007 | 08:11 AM
bag's Avatar
bag
yea it has the info for b16a3 delsol.
Old Feb 24, 2007 | 08:26 AM
msinsky14's Avatar
Default Re: b16a helms manual for 88 crx si (bag)
and that means it is the same as the jdm b16a for the mechanical aspects of the engine/tranny am I right?
Old Feb 24, 2007 | 09:03 AM
bag's Avatar
bag
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">and that means it is the same as the jdm b16a for the mechanical aspects of the engine/tranny am I right?</TD></TR></TABLE>
yeah most everything is the same,only little difference like wiring,distributor,etc..but as far as rebuilding the whole engine the book is perfect..has all the tq specs,clearences,patterns,etc,etc for any b16
Old Feb 24, 2007 | 09:30 AM
Under Con. CrX's Avatar
bro dont even waste your time with that heres a link where its the same B16a for the crx http://spoonhonda.com/downloads.htm or click ont the link below trust me it it will help you a **** load of times http://downloads.hondatech.inf...9.zip
ohh one more thing if you whant to get the manual and you clicked on the second link its on Adobe so you have to down load it in order for you to see it so when you click on just know that it will start down loading the file so you dont freak out ok hope it helps you like it helped me
Old Feb 24, 2007 | 10:08 AM
bag's Avatar
bag
Default Re: b16a helms manual for 88 crx si (Under Con. CrX)
i almost forget to add the tranny is alittle is different..90-91 is different then 92+ insied,but its still a good guide to go by reguardless
Old Feb 24, 2007 | 10:13 AM
msinsky14's Avatar
so if I was to use the manual to replace my clutch and flywheel it would be a little different since the jdm b16 is from an xsi, or will it be basicly the same thing?
Old Feb 24, 2007 | 10:21 AM
bag's Avatar
bag
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">so if I was to use the manual to replace my clutch and flywheel it would be a little different since the jdm b16 is from an xsi, or will it be basicly the same thing?</TD></TR></TABLE>
the parts are different but the procces is the same as far as the tq specs and patterns,pilot bearings,etc are concerned...
Old Feb 24, 2007 | 05:10 PM
msinsky14's Avatar
thanks man, I downloaded it. thats very helpful, but it doesnt say which file is what repair. oh well
Old Feb 26, 2007 | 07:41 AM
JustJesus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">wat u mean by "OG manual?"</TD></TR></TABLE>
I meant, like a real deal, original print manual. The one I got has all the same info as the real thing, but it's a reprint. Mine also doesn't have the cool color wiring schematics, but that's cool.
For an EF, with B16, I look toward the 92-93 Integ GSR, as this has a B17 VTEC. I recently learned this as I needed a starter. B17 is essentially a B16.
Old Feb 26, 2007 | 07:43 AM
JustJesus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under Con. CrX &raquo;</TD></TR><TR><TD CLASS="quote">bro dont even waste your time with that heres a link where its the same B16a for the crx http://spoonhonda.com/downloads.htm or click ont the link below trust me it it will help you a **** load of times
DAAAMN. where was this before i went out looking for manuals and spent like 60 bucks on a reprint? Thanks for sharing this site ! !
blazzer
17
May 12, 2023 08:48 AM
TypeR0207
Feb 9, 2002 08:00 AM
TypeR0207
Feb 8, 2002 07:08 PM
hb_racer
15
Dec 24, 2001 06:13 AM
AfEn808
Oct 17, 2001 08:47 PM
