hesitant in 1st gear
Old Feb 23, 2007 | 06:15 PM
usdmEHboy's Avatar
Default hesitant in 1st gear
b16 in 95 hatch.
When i put the car in 1st gear...its really slow when i try to go...i have to rev to like 3000 rpm or so to get it moving..it idles around 800 or so when warmed up...i've replaced spark plugs/wires/oil change..
Mods are only jasma header/Password cf intake/apex'i ws2 catback
Is there anything that could be making it hesitant in 1st gear...keep in mind that 2nd through 5th gear is perfectly fine..thanks
Old Feb 23, 2007 | 06:26 PM
hi-Powered's Avatar
check your timing.
Old Feb 23, 2007 | 06:33 PM
usdmEHboy's Avatar
Default Re: (hi-Powered)
what all do i check...i need to replace the timing belt soon...will that fix the problem maybe?
Old Feb 23, 2007 | 06:40 PM
ek_chris's Avatar
Timing belt has nothing to do with it.
He meant ignition timing.
What clutch do you have?
Old Feb 23, 2007 | 06:44 PM
usdmEHboy's Avatar
Default Re: (ek_chris)
Stock clutch...i've replaced the ignition coil in the distributer..how can i check igniton timing
Old Feb 23, 2007 | 06:46 PM
ek_chris's Avatar
with a timing light......
there's a nice write up on cspeedracing.com about it.
boarding2008
Jan 25, 2009 02:06 PM
downeyballz
Jun 6, 2005 11:10 AM
fastludeh22
Aug 13, 2003 05:41 PM
carcala
Jan 18, 2003 04:06 PM
