zc idle problem
Old Feb 23, 2007 | 05:19 PM
ryyo's Avatar
Default zc idle problem
I've got an '88 crx with a dohc zc swap. Problem is, after driving the car for a bit, the engine idles with a quick surge and then drops and continues up and down. I've been told that I might need to bleed the radiator fluid. Could this be the most likely cause or what else might it be?
Any help would be greatly appreciated.
Thanks
Old Feb 23, 2007 | 05:56 PM
janz3n's Avatar
Default Re: zc idle problem (ryyo)
could also be a vacuum leak .. might aswell bleed the coolant .
Old Feb 23, 2007 | 07:53 PM
1.6civicturbo's Avatar
I had the same problem on my 91 hacth with a dohc swap and it turn out to be th eidle screw on the throtle body it was loose and the vibration from the motor made it turn in and out so i put a bit of liquid teflon on the screw and put it back on the thotle body and adjusted the idle and i nevewr had the problem again.
Old Feb 23, 2007 | 08:01 PM
ryyo's Avatar
I had also been told that it might be a vacuum leak or the EACV. I guess I should start with bleeding the coolant and see how that works out.
Old Feb 24, 2007 | 06:31 PM
LostInTranslation's Avatar
Had a similar problem, turned out to be the ECU...
Old Feb 24, 2007 | 11:11 PM
C_R_X_V_T_E_C's Avatar
Default Re: zc idle problem (LostInTranslation)
IVAC Or FCCV
ximportman
May 3, 2007 08:27 AM
b18hondahb
16
Oct 13, 2006 05:40 PM
blackE_T
Feb 4, 2005 01:59 PM
Ham'ed Hatch
12
Oct 3, 2002 06:19 PM
zcrx1
12
Sep 26, 2002 11:02 PM
