Alarm Problem
Old Feb 23, 2007 | 04:26 PM
Nameless Warrior's Avatar
Default Alarm Problem
My alarm lock still locks, but it doesn't make that little sound before it does. I also tested to see if it'll go off if someone tamper with the car and it wont go off. Can it just dies on it own or does someone have to mess with it to die like that?
Old Feb 23, 2007 | 04:29 PM
jibs's Avatar
Default Re: Alarm Problem (Nameless Warrior)
Factory alarm?
Old Feb 23, 2007 | 04:40 PM
VegaS10's Avatar
Your alarm is in "valet" mode.
Open the door, on the keypad press lock, unlock and lock. Or, depending on the alarm model, press lock, aux, lock.
Close the door, turn on the ignition, turn it back off.
This should put it back in "alarm" mode.
This works with Viper and Python alarms.
Modified by VegaS10 at 11:12 PM 2/23/2007
Old Feb 23, 2007 | 05:03 PM
bmoua's Avatar
what if everything on the alarm works and the only problem is the siren doesn't beep when you arm and disarm it?? its not a DEI alarm but a basic alarm?
Old Feb 23, 2007 | 05:38 PM
VegaS10's Avatar
Default Re: (bmoua)
Could be a bad siren, bad siren output or a poor connection.
When the alarm triggers, do the parking lights still flash? If so, then there is a siren issue.
If the alarm won't trigger at all, it is either in "valet" mode, a blown fuse, poor conncection, or a bad transmitter.
To the OP, what model alarm is it you have?
Old Feb 23, 2007 | 05:55 PM
mywheelsbespinnin's Avatar
no need to have an alarm.. its a civic man, no one wants to steal a 5,000$ car so no worries.
Old Feb 23, 2007 | 05:57 PM
VegaS10's Avatar
Default Re: Alarm Problem (mywheelsbespinnin)
Die noob.
Old Feb 23, 2007 | 06:09 PM
Default Re: Alarm Problem (VegaS10)
Excuse me? Noob? I believe you own a civic....you're talking privileges have been revoked.
Old Feb 23, 2007 | 06:41 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mywheelsbespinnin &raquo;</TD></TR><TR><TD CLASS="quote">no need to have an alarm.. its a civic man, no one wants to steal a 5,000$ car so no worries.</TD></TR></TABLE>
haha thats all i have to say to wheelsbespinnin....anyways vegas10 i'll check the fuses. I mean its using the horn off the car so i dont see why the horn is bad? also if the door isn't locked or closed the alarm will beep...
Old Feb 23, 2007 | 07:07 PM
VegaS10's Avatar
The horn may be good, but the alarm's connection to it may be poor. The alarm's output may be bad as well.
If the alarm has been on there awhile, and has all of a sudden developed issues, it could be a connection. See if you can find the brain and just make sure all the connections are nice and tight. Especially the ground.
Alarms VERY rarely go bad. Most of the time it is a bad fuse on the alarm (not the car's fuse panel) or a ground has loosened up over time.
Also, check and make sure the battery in your keypad is in good working order.
Old Feb 23, 2007 | 07:13 PM
Default Re: (VegaS10)
I love these trolls...
Anyways, back on topic.
It's a viper alarm. An older model. The light still flash when I arm or disarm the car. I am going to try to wake it from VALET mode. Thanks for all your inputs guys.
Old Feb 23, 2007 | 07:25 PM
01_CLtypeS's Avatar
civics are stolen quite often...heres a few links to some of the many stolen civics on HT....
https://honda-tech.com/zerothread?id=1858261
https://honda-tech.com/zerothread?id=1899051
https://honda-tech.com/zerothread?id=1885387
https://honda-tech.com/zerothread?id=1891437
https://honda-tech.com/zerothread?id=1890158
https://honda-tech.com/zerothread?id=1884510
https://honda-tech.com/zerothread?id=1874976
if you need any more proof that civcs are stolen all the time then just do a quick search and trust me the list is endless.
noobs=
good luck with the alarm...if it was a KARR i could help you out!
Old Feb 23, 2007 | 07:27 PM
Default Re: Alarm Problem (01_CLtypeS)
I don't think you should pay him much attention, because that is exactly what he's trying to get. He's a troll, someone who just makes name on board to talk ****. Evidently, its friday night and he's trolling on a board. Easy to understand what kind of life he got.
Old Feb 23, 2007 | 09:49 PM
z06&gt;4 banger kthxirlowned
Old Feb 23, 2007 | 10:56 PM
94hondacivicvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior &raquo;</TD></TR><TR><TD CLASS="quote">^^
I don't think you should pay him much attention, because that is exactly what he's trying to get. He's a troll, someone who just makes name on board to talk ****. Evidently, its friday night and he's trolling on a board. Easy to understand what kind of life he got. </TD></TR></TABLE>
and who the expletive are you its friday night and what are you doing, thats right wackin off to free ****. get a job i'm at work right now
Old Feb 24, 2007 | 01:32 AM
ke98248's Avatar
Default Re: Alarm Problem (94hondacivicvtec)
Are you on crack? Civic's are the #2 car in the U.S. that are stolen! Not stolen... haha, you make me laugh!!
Old Feb 24, 2007 | 07:03 AM
Default Re: Alarm Problem (ke98248)
Update:
Well, I went to check my car out and guess what....it was ******* rigged! Some ******* tried to steal my car and cut my alarm. I pop the hood and what did I see....? Cut siren and wire. Now, I gotta go fix it.
Old Feb 24, 2007 | 08:42 AM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior &raquo;</TD></TR><TR><TD CLASS="quote">Update:
Well, I went to check my car out and guess what....it was ******* rigged! Some ******* tried to steal my car and cut my alarm. I pop the hood and what did I see....? Cut siren and wire. Now, I gotta go fix it.</TD></TR></TABLE>
damn...i should check mine too...+1 for us...
REDEM1FTW
Audio / Security / Video
Jul 7, 2011 10:46 PM
OOOtony
Mar 27, 2010 08:44 AM
Wazup
Nov 16, 2009 11:47 AM
Nocturnal
Jul 21, 2007 08:35 PM
seer_claw
11
Mar 1, 2004 02:45 PM
