EDM OBD0 to OBDI
Old Feb 23, 2007 | 02:59 PM
SickFinga's Avatar
Default EDM OBD0 to OBDI
I got PW0-X00 ECU (EDM) right now and I want to convert to OBDI.
In order to convert to OBD1 I need: ODB1 ECU, ODB0 to OBD1 harness, OBD1 distributor, 4 wire O2 sensor. Am I missing something? What about injectors?
Which OBD1 ECU I should get? Would P28 work right out of the box, or I'll need to chip it to work in B16?
Also what do I do about knock sensor? I believe EDM civic dont have it.
Thanks.
Old Feb 23, 2007 | 03:37 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: EDM OBD0 to OBDI (SickFinga)
^^^ You got the parts right, don't bother changing the injectors.
If you want a ecu to run your b16A right out of the box as you describe it, run either the rare obd1 PR3, or a P30 ecu. All others would need to be chipped before the engine would run properly.
Old Feb 25, 2007 | 09:29 PM
JDM91Bseries's Avatar
Could also run a OBD1 Integra GSR ECU(p72)...no chipping needed
Old Feb 25, 2007 | 10:22 PM
4thgenhtch's Avatar
Default Re: (JDM91Bseries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM91Bseries &raquo;</TD></TR><TR><TD CLASS="quote">Could also run a OBD1 Integra GSR ECU(p72)...no chipping needed</TD></TR></TABLE>
wrong, Deets had it right
lsvtec hf
Engine Management and Tuning
Jan 21, 2009 12:02 PM
91dxcrx
Jan 22, 2006 09:27 AM
blackcomet
11
Dec 1, 2004 07:33 PM
b16_madman
Feb 14, 2004 04:00 PM
aVstAr
Dec 26, 2003 07:41 PM
