Problems Installing Power Windows into a DX
Old Feb 23, 2007 | 02:34 PM
JaySauce's Avatar
Default Problems Installing Power Windows into a DX
Ok so I took the drivers side harness and plugged in the plug (red circle) into the back of the under dash fuse box. Installed the power window relay and the three fuses. Tried controlling it with the switch and nothing happend.
Can anyone help me out or tell me how I can troubleshoot this? Thanks.
Old Feb 23, 2007 | 02:42 PM
dem0nk1d's Avatar
bump -- I would like someone to help the homie out... i am going to do this soon
Old Feb 23, 2007 | 03:00 PM
MR.johnson's Avatar
Default Re: (dem0nk1d)
bad ground? maybe...
did you check for power at the switch, motor, fuse box...EXT...
Old Feb 23, 2007 | 03:39 PM
JaySauce's Avatar
Default Re: (MR.johnson)
bump
Old Feb 23, 2007 | 03:49 PM
dad0c402's Avatar
Default Re: (JaySauce)
i see that you have the harness that plugs into the factory fuse box. If you go that route you have to put in some fuses(what you already did) and then also put in the relay for the power windows(i'm guess this is what you need). If you look on that fuse box, on the right side there should be a big black block, basically you need the one that goes above that. Found at a dealership or you local yard.
Old Feb 23, 2007 | 04:32 PM
MiamiEJ1's Avatar
Default Re: (dad0c402)
http://repo.jackmoves.com/v/erik/albun31/albun42
read there, there's some informtion provided. Good luck.
Old Feb 23, 2007 | 10:13 PM
monicle's Avatar
Default Re: (MiamiEJ1)
both of the green plugs should be plugged in when everything is done but yeah you have it hooked up right. check for power on the connector that goes into the switch. you should have power on the white/yellow and blue/black wires. black should have continuity to ground.
Old Feb 24, 2007 | 11:44 AM
JaySauce's Avatar
Default Re: (monicle)
alright...tried pluggin in both the green plugs....didn't work...now im gonna test the motor to see if it actually works. 12v battery to the wires....
Old Feb 24, 2007 | 04:20 PM
JaySauce's Avatar
in the last picture i have the relay put it. Am i right?
Modified by JaySauce at 2:27 AM 2/25/2007
Old Feb 24, 2007 | 09:32 PM
dad0c402's Avatar
I actually can't see the relay that's why I pointed it out. Right where that picture cuts off there's two black relays kinda like the one you see at the top of the same image. The top of the two on the right is for the windows.
Old Feb 25, 2007 | 01:49 AM
JaySauce's Avatar
OK..I put a relay in the spot marked with the red arrow. It also says P/W underneath the location so im guessing that means power window? Thats the relay monicle said to put in on his instructions. Can you point out which relay you are talking about dad0c402?
What do you guys think is best way of hooking up the motors to see if they work? Should i just splice a power and ground wire from wires in my car and just jimmy rig the regulators to that?
Thanks everybody.
Old Feb 25, 2007 | 09:01 AM
monicle's Avatar
yeah you could do that.
Old Feb 25, 2007 | 05:04 PM
JaySauce's Avatar
Does anyone know for sure which wires I should connect the power and ground to in order to test the regulators? Ive look at three different wiring diagrams that say different things.
Old Feb 25, 2007 | 05:50 PM
JaySauce's Avatar
bump.
Old Feb 25, 2007 | 08:34 PM
JaySauce's Avatar
bump...
Old Feb 26, 2007 | 01:53 AM
JaySauce's Avatar
Ok...so i made a red circle around the area of interest in the diagram below. I was wondering which of the wires i need to connect power up to for it to work with the black ground wire.
There is a red/yel, red/blu and blu wire.
Which of these three or combination of does the power need to be connected to?
Thanks.
Old Feb 26, 2007 | 03:59 AM
monicle's Avatar
the blue wire is only used for auto down, connect power to red/yellow and ground to red/blue to make the window go down, and the reverse to make it go up.
Old Feb 26, 2007 | 04:37 AM
dognutz's Avatar
Do you have both sides hooked up, because I think you need to in order to complete the circut.
Old Feb 26, 2007 | 04:40 AM
ku's Avatar
ku
thats alot of wiring lol
i want power windows in my eg3 1.3 dx single carb
i will need new interior loom,relays,window motor,switch?
Old Feb 26, 2007 | 08:03 AM
dad0c402's Avatar
Default Re: (ku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ku &raquo;</TD></TR><TR><TD CLASS="quote">thats alot of wiring lol
i will need new interior loom,relays,window motor,switch?</TD></TR></TABLE>
don't forget the door panels and get them with the power switches if you can.
any luck yet jaysauce? have you tried the other door yet?
Old Feb 26, 2007 | 11:33 AM
JaySauce's Avatar
i need to drop by the store to get some connectors. I will test it out later and let everyone know whats up. Thanks.
Old Feb 26, 2007 | 12:48 PM
JaySauce's Avatar
ok regulators work now i need to test with power at the switch and power at the fuse box. does anyone know what wires i should connect power to at these to points to test it? Thanks so much for you help.
Old Feb 26, 2007 | 03:39 PM
JaySauce's Avatar
ok figured it out....so in addition to the green plug that is in monicles walk-thru, there is also a large ground connector that you have to hook up to a ground in your car. I will post pics up later.
Now i just gotta figure out how to get the passengers side to work. Any tips?
....and get rid of all the wires in the harness that i won't be needing. Thanks for the help everybody.
Old Feb 26, 2007 | 04:34 PM
JaySauce's Avatar
i got the passengers side to work...you just need to plug in one of the grey plugs in the harness. I will probably post another thread of the steps needed later.
THanks again everybody for the help.
Old Feb 27, 2007 | 01:07 AM
JaySauce's Avatar
welll...i wasted about two hours when all of a sudden my passengers side window wasn't working. I was stupid and didn't think of checking the fuse first which indeed was blown and ended up trying to find a nonexistant bad connection in the wire.
Anyone got any idea why the fuse blew? Is there a way to make sure that the fuse doesn't blow regularly after i install the regulators permanantly? Thanks.
