Why cam timing matters... Picture of King Motorsports Dummy Motor
Old Feb 23, 2007 | 01:40 PM
Ausmith's Avatar
Default Why cam timing matters... Picture of King Motorsports Dummy Motor
A picture is worth 1000 words. This is Chad's (our motor builder) dummy motor. We use it to check cam timing when working with wild set-ups that use custom cams/pistons. Yes, you can spin the motor over and actually watch the valve timing events. Enjoy...
Old Feb 23, 2007 | 01:44 PM
Rocket's Avatar
Default Re: Why cam timing matters... Picture of King Motorsports Dummy Motor (Ausmith)
That picture is almost to good to post.
Ausmith's Avatar
Default Re: Why cam timing matters... Picture of King Motorsports Dummy Motor (Don Lackey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Don Lackey &raquo;</TD></TR><TR><TD CLASS="quote">That picture is almost to good to post.</TD></TR></TABLE>
Yeah I'm giving away one of our motor building secrets.... better save it quick!
Old Feb 23, 2007 | 01:45 PM
905_Legend's Avatar
Looks like a great idea, you get to see piston to valve clearance first hand.
Old Feb 23, 2007 | 01:59 PM
hopware's Avatar
Thems some beefy valve springs mister! Thats the way to make horsepower, 2 lbs on the seat, 4 lbs over the nose! Gotta try that on my 11000 rpm build! Seriously, thanks for posting this . I come from the " assemble with light valve springs and clay school" myself. What you have there is one damn fine tool.
Old Feb 23, 2007 | 02:44 PM
SFWDcoupe's Avatar
Default Re: Why cam timing matters... Picture of King Motorsports Dummy Motor (hopware)
nice cut out!
Old Feb 23, 2007 | 03:34 PM
MotorSpecies ver1.6's Avatar
From: MoonSHINE Metropolis, .FL. Run Free, North America
Default Re: Why cam timing matters... Picture of King Motorsports Dummy Motor (SFWDcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFWDcoupe &raquo;</TD></TR><TR><TD CLASS="quote">nice cut out!</TD></TR></TABLE>
I agree.
what specs are we looking at in particular on this picture?(pistons,rods,cams,gear settings,head,valves,block, rotating assembly/crank)
O,yeah.......what stoke/cycle is the motor on in the picture?
WOOOW. clearacnce looks like it almost makes piston/valve contact. I cant visually tell.
Very Nice.
Old Feb 23, 2007 | 05:53 PM
b16nonoy's Avatar
swweet.... I agree on the beefy valve springs..lol
Old Feb 23, 2007 | 05:58 PM
NuRon's Avatar
Could you maybe get a video of it? That'll be tight.
Old Feb 23, 2007 | 06:04 PM
high_revs's Avatar
Old Feb 24, 2007 | 01:07 AM
gfunkmos37's Avatar
Default Re: (h2b_eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>x2
Old Feb 24, 2007 | 01:29 AM
RIP V8s's Avatar
Default Re: (gfunkmos37)
ncie tool, must be nice to have a long block to just cut up.....
Old Feb 24, 2007 | 05:52 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: (b20vrex)
thats fantastic to be able to see whats going to happen before you build for real. for ingenuity
Old Feb 24, 2007 | 06:56 AM
1 2 NV's Avatar
Default Re: (attentionwhore)
get a cam fixture and you wouldnt have to worry about cutting up a block/head and looking at it.
Old Feb 24, 2007 | 07:44 AM
Padawan's Avatar
Darth ModerVader
Default Re: (1 2 NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">get a cam fixture and you wouldnt have to worry about cutting up a block/head and looking at it.</TD></TR></TABLE>
Elaborate.
Old Feb 24, 2007 | 07:46 AM
1 2 NV's Avatar
Default Re: (Padawan)
you will see it in the pics.
https://honda-tech.com/zerothread?id=1891614
Old Feb 24, 2007 | 08:02 AM
Padawan's Avatar
Darth ModerVader
That's fine for checking valve-to-valve clearances, but it doesn't aid in determining valve-to-piston clearances, which is one of the primary purposes of that "dummy" motor.
Old Feb 24, 2007 | 08:08 AM
1 2 NV's Avatar
did you see the second post i made in that thread? that is P2V clearancing. so yes the fixture will help properly. besides that motor cutout looks cool and all but its only good for 1 bore size and thats even if your crazy enough to disassemble it each and every time. then if you working on a different motor you will have to measure deck height and head height for each and every different motor combo. as i said, it looks cool but i dont think its as helpful as some may think. http://www.newenglandhondarebuilders.com/
Old Feb 24, 2007 | 08:44 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">did you see the second post i made in that thread?</TD></TR></TABLE>
No, I admittedly overlooked the portion regarding piston to valve clearance. It does appear to be a relatively accurate and somewhat easy method, though the inconsistencies you allude to in your original post indicate that the results should be used with an additional safety margin (which you also mention).
Old Feb 24, 2007 | 08:56 AM
Lubo_25's Avatar
you didnt make a standard thickness headgasket cutout??...or was that on purpose...you can really have some fun with making cross sections like that hehe...looks fantastic for a machine shop reference
Old Feb 24, 2007 | 09:02 AM
1 2 NV's Avatar
it is very helpful cause as in that same post i had my P2V chart shown using my current skunk pro2s. when i used my JUN 3s last year the chart showed minimum clearances at around 9* BTDC and ATDC. as i said in that post besides VTEC being locked that motor was ready to run.
Ausmith's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">did you see the second post i made in that thread? that is P2V clearancing. so yes the fixture will help properly. besides that motor cutout looks cool and all but its only good for 1 bore size and thats even if your crazy enough to disassemble it each and every time. then if you working on a different motor you will have to measure deck height and head height for each and every different motor combo. as i said, it looks cool but i dont think its as helpful as some may think. http://www.newenglandhondarebuilders.com/</TD></TR></TABLE>
Jeeze. I said above that it's useful for visually observing cam timing events when you are working with a custom camshaft. This is not how we check piston-to-valve, or valve-to-valve.
Old Feb 24, 2007 | 09:08 AM
1 2 NV's Avatar
Default Re: (Ausmith)
i understand what you are eluding too now.
either way properly plotting cam timing events in relationship to crank degrees is the proper way to do it and i know you know this. some people need it in black and white or they still wont understand.
Old Feb 24, 2007 | 09:38 AM
Ausmith's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">i understand what you are eluding too now.
either way properly plotting cam timing events in relationship to crank degrees is the proper way to do it and i know you know this. some people need it in black and white or they still wont understand. </TD></TR></TABLE>
Agreed. This tool was an eye opener when working with a custom cam AND piston combo. When you measure P2V you come up with an absolute number - the valve is x" from the piston at this given spot. But what you can not see is how the valve head relates to the piston ALL the way through its range of motion. On this particular set-up the absolute P2V was not the problem, rather Chad noticed that the valve came waaaaaay to close to the top edge of the pocket on its way down. Basically the pocket location had to be revised otherwise the smallest amount of error would have caused P2V contact at the top edge of the pocket, not at the bottom.
Old Feb 24, 2007 | 10:46 AM
Aquafina's Avatar
Meh.
I'm just interested in a better scan of your yearbook pic in your avatar.
